motor mounts
Old May 23, 2010 | 11:24 AM
silkhope's Avatar
Default motor mounts
Anybody got any preference in how to mount the motor mounts with eng out of car? What I am getting at is this. Is it easier to install the motor mounts on the block then drop in the eng in and tighten up the remaining bolts, or the other way around. the back mount under the turbo looks like a PITA to do either way.
Old May 23, 2010 | 11:37 AM
Bobec's Avatar
I left the motor mounts in the car and left the brackets on the motor and then lined the studs on the mounts up with the bracket holes as I lowered the motor. Except for the timing belt end mount that I bolted to the motor first (the first motor I didn't do it this way and it was a pain)
Old May 23, 2010 | 11:45 AM
silkhope's Avatar
Thanks I changed out all my mounts with the eng out, I guess I will have to have help lowering the eng, so not to mess up the bolt threads.
Old May 23, 2010 | 12:12 PM
Bobec's Avatar
It's easier to have help if for nothing else than to watch as you're lowering. Are you using a block and tackle and the horses to lower it?
Old May 23, 2010 | 05:32 PM
silkhope's Avatar
Now that is an idea! With my luck the horse would spoke, and drag the eng down the gravel drive out onto the main road.
gadgetman954
Dec 22, 2008 10:08 AM
curtrapp
Mar 27, 2008 10:59 PM
kh0007
Mar 10, 2008 09:22 PM
Trk511
Mar 2, 2008 09:11 AM
Parsec
Dec 10, 2007 12:44 PM
