75k service - motor mounts?
Old Dec 10, 2007 | 12:01 PM
Parsec's Avatar
Default 75k service - motor mounts?
I just took my 2000 S40 in for a 75k service and my mechanic comes back and says I need the front motor mount replaced. The part description is "ENG MNT FRNT UP VS/40" and costs $101.15, and labor to replace is $16.10. Does this sound fishy, or does this problem occur frequently? I've noticed a vibration at idle about 10% of the time I drive the car, but it hasn't bothered me much. Is it something I really need to spend over $100 to fix or can I just leave it alone?
Old Dec 10, 2007 | 12:05 PM
Parsec's Avatar
Default RE: 75k service - motor mounts?
I also noticed the mechanic jotted down:
battery: 9.7V and alternator: 13.8V
Does the voltage on the battery seem low? It hasn't been replaced since I purchased it 3 years ago (and I'm not sure if it was replaced in the first 4 years of its life either).
Old Dec 10, 2007 | 12:44 PM
jks2's Avatar
You can probably pick up a motor mount from FCP Groton or other places on ebay for less. It is a fairly simple job to replace. If yours is broken you really need to get it replaced. It could become dangerous if left alone. Voltage on battery seems low. Take it to Autozone or similar place and they can test the battery and tell you if you need a replacement. If you got 7 years out of the battery then you did OK.
Penny99
Apr 25, 2012 01:05 PM
Volvoforlife10
Aug 16, 2010 10:32 AM
StevenA86
Nov 2, 2008 09:38 PM
curtrapp
Mar 27, 2008 10:59 PM
hohoho43
Sep 10, 2007 06:19 PM
