My 850 AWD (From then till now)
Old Feb 6, 2012 | 05:40 PM
matt01's Avatar
Default My 850 AWD (From then till now)
Hello
I'm not sure ive ever posted up what i've done to my car. So here i've compiled the full maintenance list, modification list, and maintenance left to do list, along with pictures along the way.
Car: 1997 Volvo 850 AWD (supposedly 214 in Canada)
Black Stone on Tan swapped to v70R seats
Maintence List:Maintenance Records since i've owned the car.
·1997 Volvo 850 AWD
·Windsheild Replaced (Late Summer 2011)
·Rear Wiper Motor Replaced
·Rear Sprayer Motor Replaced (01-27-2011)
·Front Passenger wheel bearing Replaced (2010)
·D+P Rear Stay Bars Replaced and Modded (12-13-2010 @ 260000)
·Underside Crossmember Repaired
·Rack and Pinion + Tie Rods Replaced (11-13-2010 @ 254600)
·Handbrake Cables and Pads Replaced (Summer 2011)
·Cap, Rotor, Plugs (08-13-2010 @ 250200) + Wires (Kingsbourne) replaced (11-06-2010 @ 254035)
·Front Tie Rod Links Replaced (Summer 2011)
·Passenger Side Motor Mount Replaced (01-27-2012)
·PCV Replaced (Summer 2011)
·Driver Side CV Boot replaced
·Gas Lines Replaced/Repaired + Fuel Sending Unit Replaced
·Vacuum Lines Replaced with silicone
·Blower Motor Replaced
·Fog Lights Replaced
·Front O2 Sensor Replaced (Winter 2012)
·Battery Replaced (Winter 2011)
·Timing Belt, Water Pump Replaced (02-25-2010 @ 241707)
·ECT (Temp Sensor) + Thermostat Replaced (Winter 2012)
·Falken Winter Tires (12-15-2010 @ 260000)
·Gas Filter (01-02-2012)
Mods Records
·IPD Intake (12-25-2011)
·Snabb Fresh Air Pipe 3” ( 01-27-2012)
·Snabb Intake Spacer (Summer 2012)
·Eurosport Tuning Strut Brace
·Snabb Short Shift Kit + Brass Bushings
·Eurosport Tuning BOV ( 12-20-2010)
·Custom Stainless Steel 3” Downpipe + Race Cat (12-14-10 @260000)
·Rear Stainless Brake Lines
·Front R Springs
·Alpine Radio + Subwoofer
·Polyflex silicone upper engine mount
Aesthetics
·850R bumper (Summer 2011)
·t5-R Walnut Shift **** (summer 2011)
·V70R Seats (Leather on Suede)
·Replika Pegasus Rims
850R suede door inserts
Left to do:
·Oil Cooler Lines
·Broken Plastic Panels
·Tie Rods + Rack and pinion Boot
·Passenger Seat Electrics
·Driver Axle Seal
·Gas Gauge again
Pictures
First Day I owned it:
Enough of that
The interior was a nightmare (dirty as hell) after a small cleanup:
One of my first mods:
changed it out for some R springs in the front:
after a cleanup
then I got my Replika Pegs
I had a leak from my stock downpipe, so i had a new one built for me:
Then the eurosport strut bar
Then i got the R bumper
then i painted it
Continued...
Old Feb 6, 2012 | 05:41 PM
matt01's Avatar
Then Snabb FAP
Engine Now
After Detail
Interior after big cleanup (shampoo)
OTHER:
I modded the rear "stay" bars because they kept breaking
Dropped the subframe to fix some of that up.. ( Ive done it 3 times now)
Which takes us to now.. Winter time
**update** V70R seats + interior pictures
Driver seat ( looks good in pictures)
Old Feb 6, 2012 | 06:44 PM
MC92's Avatar
Neat! That Canadian weather sure took a beating to your car. I think my car has all original suspension parts. Ball joints, struts and all. Btw how did you clean your carpets. Did you use a carpet cleaner or just scrub the dirt out? The last few years that my relatives owning my car used it for deliveries for their restaurant, so messy carpets.
Old Feb 6, 2012 | 06:52 PM
Ok, I have a few questions:
1. What was all the powder looking stuff on the motor in the early pic?
2. How did you get the motor looking so clean?
3. Have you thought about doing Forever Black on your trim?
4. Do you take your R bumper off for the winter?
5. When you said "you painted it" did you paint the entire car or just the R bumper?
6. What kind of fogs did you go with in the R bumper?
Nice looking black wagon.
Old Feb 6, 2012 | 06:54 PM
MC92's Avatar
Just have to say this, powder stuff= cocaine Makes sense if you seen the movie "The Other Guys".
Old Feb 6, 2012 | 07:28 PM
Good job on the wagon Matt!
Old Feb 6, 2012 | 09:40 PM
matt01's Avatar
The paint is pretty rough on it, it takes alot to get it to look alright, im a detailer, so it drives me crazy all the scratches/dings, but i have no money to paint it right now.
For carpets, i used both, the shampoo machine works great for getting out salt stains (so does hot water and a brush) and dirt, not so great for stains.
For stains, you might have to try multiple products. What i used was a toyota product called bio-solv (its amazing to put it lightly) we use it for everything. You might be able to buy some if you ask at a toyota parts counter and the guy knows what he's talking about. Basically spray it in, and scrub with a brush + repeat. When your down spray it down in hot water and vaccume it out, (like a carpet cleaner). I even carefully sprayed it onto my alcantara seats and it worked good. Takes sometime and surely you can get almost anything out.
Be careful with that stuff (or any degreaser or cleaning product really) bio-solv was tested to not damage a TOYOTA, i use it on my volvo but with no guarantee that i wont harm some of my plastic/material.
1.It's just dust and dirt. The guys driveway wasnt paved.
2.^Biosolv again.. Its a degreaser product I use at toyota, sprayed that ( you could use an engine greaser aswell i guess, but I have access to free products at work) let it sit, then carefully pressure washed it. Covered the intake and motor etc with plastic to not get water anywhere it didnt belong. Worked good. Also many hours with cloth in 1 hand and a spray bottle in the other, I have a car club so I go to alot of meets, got to keep it looking reasonable.
3.I skipped that part of the writeup, but the only trim i haven't taken care of yet.. You'll see what ive got when i'm done.
4.Yep, i like to drift alot, and plow through snowbanks too, R bumpers are expensive.
5.Ya i painted just the bumper, i did a writeup on VS about it. Wish i could paint the whole car.
6.i used stock 850 fogs ( the ones that came on the car stock) there are no differences with the R fogs. Just one of them does not line up perfectly when i install the R bumper
Thanks.
thanks, it seems like the work never ends, normally i have to fix things twice due to used or jobber parts, also i'm learning so i screw it up sometimes too.
1/4 mile and lapping doesnt help either
Old Feb 6, 2012 | 10:00 PM
matt01's Avatar
some paintwork i did this summer ( it probably already looks like crap... stupid winter)
1 step compound, glaze + a couple hours.
All the swirls were gone. Up close the hood looked like the night sky, full of stonechips. But its original paint 15 years of winters...
Bonus:
I even wax the rims sometimes, it makes them shine, and brake dust washes off nicely.
Snow Drifting vid featuring my and some buddies for your watching pleasure
Winter Snow Drifiting - YouTube
Old Feb 6, 2012 | 11:45 PM
boxpin's Avatar
Matt01, your car has come a long way...lookin' good!
Old Feb 7, 2012 | 06:56 PM
I hear you on tracking. That is why I had to do a motor rebuild on Yellow.
The car looks good!
Old Feb 7, 2012 | 07:11 PM
boxpin's Avatar
Hah, I just watched the video...silly Canadians.
Old Feb 7, 2012 | 07:42 PM
matt01's Avatar
The car looks good!
Ya, i remember reading about that. I got screwed with my chip, its a long story I won't get into it, let's just say that that my mods list is missing a tune, white injectors, which are bought and paid for. ( then a 16T)
they say you got to keep warm in the cold winter nights.. since i don't have a GF.
Theres a GB on AWD sways on Swedespeed right now, im on the fence about it, just started a semester, but i wont get 20% off again.
Old Feb 7, 2012 | 08:23 PM
Matt: Great job with the wagon. I didn't even notice the R seats.
I would be afraid to drive my car like that in the snow. I'm not real comforable with the suspension in these FWD cars. I think the weak link is the front suspension. I remember back in the 80's when Volvo was driving the 760/740 down train tracks to prove how tough they were. I bet they wouldn't do that with these FWD cars for 1/2 block. LOL
Again, great job with the wagon. I forgot it was AWD.
Old Feb 7, 2012 | 09:39 PM
matt01's Avatar
Yep LPT AWD 5-speed. I updated the pics with the V70R seats today. But it was written in the "aesthetic" section
ya, i need to use my car everyday, so some of my buddies really go insane with the drifting, sometimes hit curbs, (the snow hides them nicely) and i cant afford to have much downtime with my car, plus the cost of repairs for being stupid. So i really pay attention and normally only go in open parking lots.. It takes alot of practice being the car is not a clear 50/50 front, rear split, its unpredictable, sometimes i can get into a nice drift, sometimes just understeer. It's just a shame that the handbrakes suck on these cars, can't really drift the FWD's easily.
Update: I forgot to add a picture of this. Got it from a local, came out of a yellow..
Old Feb 7, 2012 | 10:12 PM
OMG!!! Not sure why they didn't trust us with manual R's.
Old Feb 7, 2012 | 10:18 PM
matt01's Avatar
ya, i have a pretty rare car.. but although it has R seats, T5 R ****, i have my R suede inserts to pick up, R bumper, it's still not an R. If ever i find one, i might have a hard time resisting.
Too bad that one fell into the wrong hands.
Old Feb 13, 2012 | 12:21 PM
  #17
matt01's Avatar
i updated the interior pictures after a quick clean today.
the good news is it seems to start alot easier these days..
Old May 23, 2012 | 02:24 PM
  #18
Ace_Rosswell69's Avatar
my 1997 855 AWD has a lot of the same mods!
i have the same **** from a 97 black 850R stick wagon, 850R seats from the same car! i thought of swapping out the seats from my 98 V70R but decided to keep it 850R where i could, i have the bumper but still need the spoiler, i have a water-to-air intercooler to put in yet and an AFCO racing RAD, and i'm looking for a 19T and a B5234 to build. right now it just has a 16T. i also have a few other goodies waiting for it when i start driving her next spring! lots of pictures to come when i get everything together.
you might remember my video of 2 855 AWD's on youtube? you corrected a bit of my misinformation lol
i actually wrapped the black AWD around a hydro pole after a figth with a female and a few bad decisions but we wont go there...
now i have my baby 855 AWD (burgundy) , a 98 V70R (black) soon to be 5 speed! parts suppied from "big sexy"(R.I.P.) and a 99 non turbo 5 speed V70 for my beater lol (BLACKED OUT!) maybe flat black in the future
Lots of love From B-K Volvo Waterloo!
you car looks amazing!
kelsodatrini
May 28, 2013 05:59 PM
Wes Cheng
Jan 3, 2013 11:30 AM
zmontgomery
Jun 29, 2011 04:59 AM
Dennis Bor
May 30, 2011 11:14 AM
mstrplmber
Jun 26, 2010 04:10 PM
