My 850 Stalled on me
Old Dec 16, 2005 | 12:21 AM
Riculus's Avatar
Default My 850 Stalled on me
Hi,
My 850 stalled on me last week so I looked in the manual and changed the fuel filter as per its recommendation. However i just had the same problem. It stalled on me again. Can someone give me some advice on what to do.
Thanks
Riculus
Old Dec 16, 2005 | 09:09 PM
Default RE: My 850 Stalled on me
Look on the end of the head on the left side of the car. There is a sensor mounted in the end of the head. Called a Cam sensor. follow wire and look at the white part of the plug. They get soft and fall apart.
It could also be a bad fuel pump relay.
Old Dec 19, 2005 | 10:12 PM
Riculus's Avatar
Can it be an ignition problem. A mechanic told me it could the module or the crank sensor or something of that nature.
Help.
Old Dec 19, 2005 | 10:26 PM
It could be. It could also be a bad fuel pump relay,Fuel pump,Mass flow sensor,Tps sensor, ETC.
Old Dec 24, 2005 | 09:21 PM
Riculus's Avatar
I took the car to AAmaco to do a complete diognostic test. The found no errors and it showed up no codes. The transmission fluid was burnt and he said it could be that the soliniod is damaged so I would have to rebuild the transmission or get a new one. What is the best way to go, rebuild or buy a used one from the junk yard or somewhere. Im in Brooklyn NY so if anyone knows where to find one.
Thanks for ur help.
Old Dec 25, 2005 | 12:48 AM
Best bet would be to have ot rebuilt.
Old Dec 25, 2005 | 04:51 PM
Riculus's Avatar
Thanks, Happy holidays
Old Dec 26, 2005 | 01:24 AM
robert213's Avatar
ORIGINAL: Riculus
I took the car to AAmaco.. The transmission fluid was burnt and he said... I would have to rebuild the transmission or get a new one. What is the best way to go...
Get a second opinion from another shop.
bryan.pedigo
Sep 30, 2013 09:32 PM
brandoncordell
Sep 21, 2006 10:24 PM
jmc00v70
May 26, 2006 04:16 PM
carol
Mar 6, 2006 08:08 AM
Liz_XC70
Jun 30, 2005 07:56 PM
