N.A. cams?
Old Sep 23, 2010 | 12:06 PM
  #21
ibified's Avatar
Right, I know what they come on, but finding one of those in a boneyard is HUGE.
Old Sep 24, 2010 | 07:50 PM
  #22
garlendrix's Avatar
Would 98-2000 V70/S70 n/a cams be the same as the 850's?
Old Sep 24, 2010 | 07:52 PM
  #23
Maybe the 98's but not 99 or 2000's.
The 99 and 00 have VVT pulleys.
Old Sep 24, 2010 | 07:56 PM
  #24
garlendrix's Avatar
Wow Tech that was quick! lol. I'm thinking of calling around to some junkyards to find a set. I saw a set on Ebay for like 80 bux, is that what I can expect to pay?
Old Sep 24, 2010 | 07:58 PM
  #25
Somewhere around there. I have seen them for as high as like $125.00.
Old Sep 24, 2010 | 08:09 PM
  #26
garlendrix's Avatar
Will any year n/a 850 cams work?
Old Sep 24, 2010 | 08:11 PM
  #27
I hear the 93's are the best. But any year 850 N/A cams should work fine.
Old Sep 26, 2010 | 10:56 PM
  #28
ibified's Avatar
T5 cams versus N/A cams
N/A
Intake:250dr duration 8,45mm lift
Exhaust:252,6dr duration 8,45mm lift
T5
Intake:242dr duration 7,95 lift
Exhaust:243,5dr duration 7,95 lift"
found that on volvospeed.com while i was looking for the thread i posted about earlier.
Old Dec 18, 2015 | 06:39 AM
  #29
Orly37's Avatar
Default Volvo 2000 C70 t5
Hi Tech. ... what yr and model NA cams can I put on my 2000 Volvo C70 t5? Any ideas?
Old Dec 18, 2015 | 02:48 PM
  #30
Keep in mind your 2000 C70 has VVT so the older post suggestions on NA cams doesn't directly apply.
If you want to put in aftermarket cams, check out
Performance Camshafts, Volvo - ViVA Performance
and look for the specs on the 2000s with VVT.
With that said - adding a cam to a turbo engine is a long hard way to get some performance gain. Simpler route is to add a bigger turbo (ie 18T), bigger injectors, 3 inch downpipe/free flow cat and get a quality ECU tune. Those mods will put you around 300+ HP, enough to make you wish for a manual transmission and a limited slip differential. In order I'd do the tune, turbo, injectors, downpipe, cat...
Old Dec 18, 2015 | 09:58 PM
  #31
Orly37's Avatar
Thank you so much for your fast reply,,, looking forward to some of does mods,,, what injectors should I'll go for with does mods and what car should I'll get the 18T from?
ibified
Sep 1, 2010 08:48 AM
pdieni
Jun 24, 2010 05:01 PM
rallysuperstar
Engine & Internal
Apr 12, 2008 04:25 PM
JimKW
Nov 29, 2006 09:06 PM
dmelvi007
Feb 18, 2006 12:01 AM
