NA cams in a turbo?
Old Apr 1, 2012 | 07:27 AM
silkhope's Avatar
Default NA cams in a turbo?
After doing a quick search, I could not find what year NA cams will work in a turbo. I thought Gabe used 1993's? Will any year NA cams work in my 1994 turbo?
Old Apr 1, 2012 | 07:36 AM
Yes they will. I am running the later N/A cams in the Yellow car.
Old Apr 1, 2012 | 08:41 AM
silkhope's Avatar
Thanks! Great to hear from ya!
Old Apr 1, 2012 | 10:11 AM
gilber33's Avatar
Any year will fit, but apparently the 1993 NA cams had the largest duration.
Old Apr 1, 2012 | 02:27 PM
91shelby's Avatar
dont you have to play with timing too when doing so
Old Apr 1, 2012 | 03:00 PM
gilber33's Avatar
You can if you want. I have both of mine set at TDC and they're fine.
Old Apr 3, 2012 | 06:30 PM
MattyXXL's Avatar
Same here... 93's set to tdc.... Have gotten up to orlando for alan to adjust mine yet... wink wink...
Old Apr 6, 2012 | 03:26 PM
silkhope's Avatar
Was at the pull a part yard today, and got a pair of 1998 V70 NA cams. Will they work? All the 850's had really high mileage on them.
Old Apr 6, 2012 | 03:42 PM
boxpin's Avatar
Should be fine, I dont think you need to worry about mileage on them. Sounds like you already 'GOT' them. Do you have a Mic at home that you can see the difference? Its not much but you can see with a mic. Here are my 93's...guess which is which (N/A vs Turbo)...
Old Apr 6, 2012 | 06:35 PM
MattyXXL's Avatar
N/A on the right?
Old Apr 7, 2012 | 05:34 AM
silkhope's Avatar
I agree, NA on right
Old Apr 7, 2012 | 10:48 PM
boxpin's Avatar
N/A on the left, Turbo on the right. There is about a mm more lift but you can hardly tell with the eye.
Old Apr 8, 2012 | 11:39 AM
MattyXXL's Avatar
LOL... the one on the right looked like it has a wider lobe.... but a more narrow lobe means taller which means higher lift....
I wish to change my answer...
Old Apr 11, 2012 | 02:14 AM
ibified's Avatar
you can leave timing at tdc or you can choose to play around with it a bit. I know that the ard tune suggests +2/-2 on can timing with their tune...
garlendrix
Dec 18, 2015 09:58 PM
96turbo850wagon
Engine & Internal
May 12, 2015 08:08 AM
rallysuperstar
Engine & Internal
Apr 12, 2008 04:25 PM
JimKW
Nov 29, 2006 09:06 PM
dmelvi007
Feb 18, 2006 12:01 AM
