Need some help...
Old Mar 16, 2005 | 02:16 PM
montalvo's Avatar
Default Need some help...
Hello Tech...
Thanxs for the pervious tips and advise..... I'm pretty new to this volvo 850 troubleshooting.
Is there a way to manually adjust my fuel to air ratio? I know my 02 sensors send the signal to have it adjusted, but can I tune manually also. I have a fuel/air meter hooked up and its alittle to much on the rich side. Also, I'm planning to install new O2 sensors - the OEM are $$$$$. $144.00 for the front and $116.00 for the rear. Do you know of using a Universal O2 sensors on a 850? I've heard it can be done...is that possible? If so, whats the cross refference from the OEM for bosch? I think the last two digits on the part number are ####29 to be used for the front O2 sensor and ####30 for the rear for the universal. Could you verify this???? Also, I'm planning to replace my CAT with an Universal Catco CAT, the specs are a good match. Do you have any advise on this????
Thanxs
Old Mar 16, 2005 | 02:41 PM
Default RE: Need some help...
I have not messed with universial O2 sensors.I would try to stay as close to stock as possible.As far as I know there is no way to make it run leaner.Check all your vaccum lines really good and pinholes os cracked lines would make it run richer.You could try installing the new O2's and cat first and see if it is still running rich.
In a way you are better running rich than running lean.
Old Mar 16, 2005 | 03:35 PM
montalvo's Avatar
Thanxs alot......
Old Mar 16, 2005 | 03:39 PM
montalvo's Avatar
Thank you.....
Old Mar 16, 2005 | 04:16 PM
Your welcome let me know how you make out.
Lansdowne
Sep 22, 2014 01:02 AM
rusvolvo
Nov 24, 2011 02:18 PM
jderosa3
Mar 20, 2011 03:01 PM
Sanel30
Feb 18, 2010 09:16 PM
B1mmer
Dec 18, 2006 11:24 PM
