New here, considering an 850 Wagon, Some questions
Old 03-01-2014, 01:39 PM
gdog's Avatar
Originally Posted by mackguy
OK, good to know. That would definitely be something to check if I proceed with this idea. What do these sell for in decent shape? I can't find any others for sale!
I don't think it's a turbo, wouldn't it have a badge on the back if it is?
Got it last November. I had been looking to build next to the house, but this came up cheaper than just a new shell, and had the lift, compressor, tire stuff, and some misc other enhancements. Low ceiling area to the right is an office with full bathroom that I set up my weights in, and a little lounge area.
OMG, the ultimate man-cave!! Where do you live? When can we come over?
Doubt that car you're looking at is a turbo but just look under the hood; if it's there, it will be hiding under the heat shield on the back of the engine.
  #22
Old 03-01-2014, 02:48 PM
Good eye, it was a cut and paste from a push rod example of a hydraulic lifter.
Kyle17428, In your world is a hydraulic lifter in an overhead cam operated differently than a hydraulic lifter in a push rod engine ??
I was addressing you saying the lifter wasn't pressurized. You were wrong, it is pressurized by oil to self adjust to make up for any slack or clearance it finds between the surface of the cam and the end of the valve stem.
Using your strength to say the lifters spring is what takes up the clearance is well, naive. The spring inside the lifter will easily collapse when run without the oil pressure as the valve springs tension is so much greater.
Don't take my word for it, search wiki or a cam manufacturers site to see if you can come up with one authoritative source saying the lifters spring is what is used for the self adjusting feature and I'd gladly pull my comments as an apology.
Mackguy, Is that your RX-7 and what do you have under the hood ???
I'd give almost anything to have that kind of room to work in.
Attached Thumbnails New here, considering an 850 Wagon, Some questions-83-rx-7-hood-off.jpg   New here, considering an 850 Wagon, Some questions-drivers-side-rx-7.jpg
  #23
Old 03-01-2014, 03:02 PM
As for the turbo, might have a badge right next to the "850" on the back but I pulled mine. It should have "Turbo" molded into the air filter housing as the trubo and non turbo use different air filter housings. I'm pretty sure but not positive the covers don't interchange.
  #24
Old 03-01-2014, 09:07 PM
mackguy's Avatar
I'm in North Carolina, bit of a drive for you it looks like.
It's a 79, run it in SCCA so under the hood is "stock" mostly. Some prep work but the class is fairly restrictive.
Lansdowne
09-22-2014 01:02 AM
AnEskimo
06-08-2013 09:12 AM
schott1984
07-19-2010 01:26 PM
Mr. Phil
01-06-2010 02:53 PM
IOWA_VOLVO
03-15-2007 10:12 PM
Quick Reply: New here, considering an 850 Wagon, Some questions
