New to Volvo's and NEED HELP!!!
Old Jul 21, 2011 | 02:52 PM
EuroLo89's Avatar
Default New to Volvo's and NEED HELP!!!
Hello everyone, I just purchased my first Volvo yesterday which is a 1996 850GLT and it has a blown head gasket, anyone give me any tips o how to go about changing this out?
Thanks for your help...
Old Jul 21, 2011 | 07:42 PM
fcpgroton's Avatar
Former Sponsor
Welcome to the Forum.
Your best bet is to do a search and everything you can find on head gaskets. Typing it all out again is just not worth the work.
Old Jul 22, 2011 | 10:41 PM
EuroLo89's Avatar
Ok, thanks bud.
Old Jul 23, 2011 | 02:48 AM
antonio's Avatar
is it something wrong with the car engine?
Old Jul 23, 2011 | 12:26 PM
ShowTek's Avatar
Well yes, he has a blown head gasket haha.
Also, good luck with the car and keep us updated!
Old Jul 25, 2011 | 10:33 PM
EuroLo89's Avatar
Well, I bought the car off of craigslist for $600.00 and the guy said it had a blown head gasket. I checked the oil the other day and it looked clean, so idk; but I'm going to go ahead and take his word for it and change it out. I would try and start it, but the ******* took the ecu and battery out and I didn't know it.
Old Jul 26, 2011 | 05:08 PM
fcpgroton's Avatar
Former Sponsor
I bet the care is probably ok as long as the oil and coolant is clean. It could be blow between the cylinders though. A compression test would be the first thing I would do before pulling anything apart.
Old Aug 1, 2011 | 10:42 AM
EuroLo89's Avatar
Well I tore the motor apart Saturday morning only to find that it did have a blown head gasket and one of the piston is actually chipped to where I can see the piston rings below it. So, I'll be getting another piston from a local junk yard and putting new ring's and bearing's in the motor as well. So, in doing this; do I run standard bearing's and ring's, or will I have to get them oversized?
Old Aug 1, 2011 | 06:33 PM
fcpgroton's Avatar
Former Sponsor
You should not have to get them oversized unless you are going to have the cylinder walls bored. I would have the opening checked to make sure it is still within spec because you don't want to put new rings and everything in there to find out that you have bad compression because the gap between the cylinder and cylinder wall is to great.
Old Aug 1, 2011 | 07:15 PM
EuroLo89's Avatar
Ok, so how do I go about doing this and also what do the letters mean that are on top of each piston?
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
uenvyboykin
Dec 29, 2008 02:47 AM
benisasome101
Nov 22, 2008 11:01 AM
