No gas gauge
When I test drove the car, the gas gauge worked. When I picked it up it didn't. I changed the sending unit, but that did not
do it. A guy at a used parts place today told me to check/change the fuel pump. even though it works, he said the float may
be broken, and that's why the gauge does not work. Any thoughts, anyone?
Hello again fast850r,
It could be:
1. Float: Highly unlikely but it may be sticking. Try using a bottle of fuel system cleaner as a cheap alternative.
2. Gauge itself: Tap the top of the cluster several times to see if it frees it up.
3. Electrical connection: Try locating a loose wire.
Good luck,
JPN
It could be:
Good luck,
JPN
J. H. McCharen
May 26, 2014 11:26 AM
bartman
Sep 4, 2008 08:35 AM
bartman
Sep 2, 2008 01:46 PM
