Noise in Rear brakes
Old Aug 28, 2007 | 06:01 PM
Riculus's Avatar
Default Noise in Rear brakes
Hi All,
When the car is cold it is normal. When I drive for a while(about 20 min) when I stop you get a vibrating sound that is VERY loud. It sounds like i'm draging something. I took the wheels off and check to see if something was stuck in the wheel but there was nothing. It is in both rear wheels but louder on the right side. I would like to know if anyone ever had a problem like this before. Thanks for the feedback.
Riculus
p.s. I changed the rotor and the brakes last year.
Old Aug 28, 2007 | 06:16 PM
RedTurbo850's Avatar
Default RE: Noise in Rear brakes
How do the pads look?
Old Aug 28, 2007 | 06:58 PM
Riculus's Avatar
They good, I don't see any sign of damage.
Old Aug 29, 2007 | 04:19 AM
JPN's Avatar
JPN
Could be the parking brake shoes?
Did you replace the rotors & pads with OEM? What about the spring kits, did you replace them as well? Did you replace the pad shims with half-size version?
JPN
Old Aug 30, 2007 | 01:53 PM
Riculus's Avatar
Yes, the rotor and brakes came from the dealer. Not shore if they havethe shimes.
When I brake normally it is fine, its only when the car is coming to a stop thats when you get that dragging sound.
Riculus
Old Aug 30, 2007 | 05:39 PM
Install the Half shims and that should take care of it.
Old Aug 30, 2007 | 11:08 PM
Riculus's Avatar
Is the shimes all I need or I need other stuff to install it. and can I get some instructions on how to do it.
Thanks,
Riculus
Old Aug 30, 2007 | 11:56 PM
Shims go right behind the bad. You're supposed to cut a square out of it, but the question is which way do you put them in...
Old Aug 31, 2007 | 10:50 AM
JPN's Avatar
JPN
The shims come with directional arrow, though as RedTurbo says, it is not clear which way the shims should face. I installed mine with the arrow pointing UP, and with the help of CV-joint grease (moly-based), no noise problem occurred ever since. Silicone-based grease seems to work just as well.
I would also replace the pad retaining spring tensioner kits, which is only about $6 a package.
http://www.fcpgroton.com/volvo850brakes.htm#rear_pads
I wish you luck,
JPN
[IMG]local://upfiles/6892/9BEB9D63B3CA4053A33643E69B6E4AFC.jpg[/IMG]
[IMG]local://upfiles/6892/B5190D756687423691E705DA5128347A.jpg[/IMG]
Old Aug 31, 2007 | 05:06 PM
^Yeah, but the arrow is so confusing. You always forget if it's pointing up or down lol. It could theoretically be pointing any direction.
Old Aug 31, 2007 | 06:17 PM
JPN's Avatar
JPN
Agreed, the kit definitely needs an instruction[8D].
JPN
Old Aug 31, 2007 | 08:44 PM
The Arrow is supposed to go Up.
Old Aug 31, 2007 | 08:57 PM
JPN's Avatar
JPN
Yay!!
JPN
Old Sep 2, 2007 | 01:11 PM
Riculus's Avatar
Thanks for the feedback guys, I ordered the shims and the pad retaining spring tensioner. I let you guys know how it works out once I get it done.
Riculus
Old Sep 2, 2007 | 03:21 PM
JPN's Avatar
JPN
Hi Riculus,
Wish you luck, will wait for your update.
JPN
Old Sep 7, 2007 | 06:38 PM
Riculus's Avatar
The rear brakes had shims, however mymechanic decided to put the new shimson the old ones. So I have double shims and new hardware. I used it for work today and I did not get the noise. Thanks for the help Tech, jpn and the rest of the guys.
Riculus
Old Sep 7, 2007 | 07:47 PM
  #17
JPN's Avatar
JPN
Well done!
Should the noise come back, try moly-based grease (CV-joint grease) or silicone-based grease.
JPN
AnEskimo
Jul 16, 2013 10:27 PM
Benjammin'
Mar 24, 2010 06:14 AM
nstanton
Oct 29, 2009 10:03 AM
cdaraghy
Nov 30, 2008 09:53 AM
oneisraeli
Jun 10, 2006 07:04 PM
