Noob Here. Heat Question ?
Old Jan 2, 2009 | 12:19 PM
Nick0887's Avatar
Default Noob Here. Heat Question ?
Hey everyone, I just bought a 1994 Volvo 850 Turbo and I have a quick question about it. Everything seems to be fine with the car except for a few things and I know a decent amount about cars in general but this has got me stumped lol...
I bought the car about a week ago when I was driving it the heat would work but it made a really loud noise when put on sounds like the blower was making a noise or a fan was loose. It was no big deal I was going to fix it later on. But I pulled in to kfc and I put the heat on and then all of a sudden it wouldn't go off I put it on the off position and nothing, I shut the car off and still nothing. It just stays on high so I actually had to pull the number 5 fuse out for it to shut off. Now when I want heat I have to put the fuse in and take it out when its snowing out kinda aggravating lol. Before I wire up a switch to it I was wondering if anyone has had this problem before my only guess is the controller is no good like where you turn the heat on and off but when the fuse is pulled and I put it on and then off you can hear a relay kick on and off. If anyone can help me with this it would really be appreciated thanks, Nick.
Old Jan 2, 2009 | 12:24 PM
Default RE: Noob Here. Heat Question ?
Could be the blower resistor. Or maybe the controller.
Do the lights in the controller flash when starting the car?
Old Jan 2, 2009 | 12:29 PM
Also follow link to learn how to pull codes from your car.
http://www.troublecodes.net/Volvo/
Also see following post for descriptions for the codes.
https://volvoforums.com/m_52326/tm.htm
Old Jan 3, 2009 | 04:29 AM
Nick0887's Avatar
the lights on the heat control like the ac light and the one of the side of it have flashed before after this heat problem.. and thanks for the help
Old Jan 3, 2009 | 10:21 PM
Psaboic's Avatar
Sounds like the ECC might be going bad. Pull the codes like Tech advised.
Old Jan 4, 2009 | 08:44 AM
Ozark Lee's Avatar
Ifthe blowercontinues to run after you turn off the key it is a shorted out power stage (blower resistor).
...Lee
Old Jan 4, 2009 | 04:50 PM
JPN's Avatar
JPN
Here is the OEM pats source we often use:
http://www.fcpgroton.com/category-ex...137/by_year/44
$75 for a resistor. If you can find a junked 850 or used resistor, you could defer the repair until later by using used resistor. If it were my 850, I would put the new one in right away, though.
Good luck,
JPN
thirdcar
Aug 24, 2007 11:35 AM
FarCanal
Aug 2, 2007 03:19 AM
RichL73
Jun 23, 2007 03:25 PM
nactall
Jun 20, 2007 03:52 AM
spitfire
Aug 12, 2006 06:14 PM
