not much boost and doesnt shift wen cold
Old Aug 24, 2009 | 10:08 PM
3seriescr250's Avatar
Default not much boost and doesnt shift wen cold
hey guys i just got a 95 obd2 volvo 850 turbo and it runs great and i just got a new radiator in it and its doing good but, when i fully get on it the turbo gage goes about 1/3 of the way on the white and i dont know if thats rite or not and when the car idles, i can here a little air leeking noise rite were the turbo is. also, its an automatic but when i first start it up for about 5 minuts of driving it wont shift i have to put it into the gears manualy...maybe it needs a tranny flush im not really sure and im new to volvos soo i have no clue about anything thanks
brent
Old Aug 24, 2009 | 10:23 PM
gilber33's Avatar
What do you mean you have to put it into the gears manually? Is it a manual transmission? And if your hearing an air leak by your turbo, well then that's why your not boosting. And on a stock 850 turbo, the needle should only make it about half way in the white.
Old Aug 25, 2009 | 11:14 AM
fcpgroton's Avatar
Former Sponsor
First, you have some kind of boost leak. I would check the vacuum lines running from the turbo and the wastegate.
Second, you should take a look at your trans fluid. From the sounds of it, it needs to be flushed ASAP.
Old Aug 25, 2009 | 09:55 PM
ok thanks ill do get that done
endneu913
Mar 28, 2010 11:41 PM
markjenross
Jan 20, 2008 08:44 AM
markjenross
Nov 15, 2007 03:33 AM
markjenross
Nov 7, 2007 07:59 PM
markjenross
Oct 1, 2007 06:27 PM
