Not your run of the mill Antenna question
Old Dec 28, 2008 | 03:55 PM
Adrenalin540's Avatar
Default Not your run of the mill Antenna question
I have done some searching and see posts where the antenna runs doesn't run, replace etc. I have gone beyond that. I found that the motor will run when power is applied directly to the motor. But there is a PCB (printed circuit board) with the relay on it mounted to the antenna. In applying power to it there is no engagement, so the PCB or one of the components failed on it...It looks like J1 (jumper 1) has been burned, or is missing...does anyone have any experience with this? Is this jumper not needed?
Thanks again
Old Dec 28, 2008 | 06:23 PM
Default RE: Not your run of the mill Antenna question
Ok, it is not the jumper, I have a shorted transistor. So, I will be looking for a replacement transistor tomorrow...I will update this post after I get the transistor replaced...
Old Dec 28, 2008 | 10:43 PM
Psaboic's Avatar
Good find!
phildo
Jun 28, 2013 10:48 AM
bsobo
Apr 20, 2010 08:18 PM
boxpin
Nov 16, 2009 08:15 AM
alecw81
Jan 7, 2009 05:22 PM
bethanybreeze
Nov 8, 2006 09:31 PM
