ODB II Scanner Advice
Old Feb 22, 2010 | 05:31 PM
brianb's Avatar
Default ODB II Scanner Advice
Hey guys...Just had my 'Check Engine' light come on last night I am thinking of buying a scanner. Which one do you use/recommend? I want one that will clear the 'Service' light (if not too expensive) and that I can use on my Mustang.
Old Feb 22, 2010 | 05:59 PM
brianb's Avatar
Was just looking at this one:
http://www.obdcom.com/?gclid=CK7xpreSh6ACFQ2kagod0zg5pg
Old Feb 22, 2010 | 06:56 PM
fcpgroton's Avatar
Former Sponsor
I would get a ScanGauge 2. It will give you real time information about what is going on with your car and when needed, you can scan the ECU for codes and reset it. As for the service light, you should be able to reset it without a scanner.
Old Feb 22, 2010 | 07:03 PM
brianb's Avatar
Thanx...The OBDCOM also does do real-time and is about $70 cheaper. It was to my understanding that you could only reset the service light without a scanner on the OBD I cars ('94 & '95). The '96 and up (such as mine) needed a special scanner. Resetting the service light isn't must, it's just an annoyance. It'd just be a nice extra to have.
JimKW
Oct 5, 2007 12:32 PM
linusvolvo
Nov 16, 2006 12:28 AM
tomservo
Oct 25, 2005 11:58 PM
JimKW
Aug 4, 2005 12:07 AM
nandrolone
Jul 25, 2005 02:21 AM
