overheating help plz
Old Feb 21, 2010 | 07:28 PM
james_caza's Avatar
Default overheating help plz
Ok so I have an overheating 96 850 turbo
What Ive recently replaced
tstat
radiator
waterpump
timing belt
reservoir tank and lid(green)
flushed system including rad and heater core
checked plugs for green tinge and fouling
checked fan and relays.
I have no signs of HG failure except for the magical coolant leak and overheat.
I just called a mechanic and he said over the phone that it could possibly be an intake manifold leak?
Could he be right?
How does coolant get near the intake?
Old Feb 21, 2010 | 08:00 PM
I am going to say headgasket is bad.
If everything is new and it still overheats then the HG is bad.
Try to have a block test done(Exhaust gasses in the coolant) and see if it passes.
Also another way to tell without that test is to start the car and run it for like 2 minutes.It will not come up to normal operating temp that fast. Then try to open the coolant bottle cap. If there is alot of pressure then the HG is bad.
Old Feb 21, 2010 | 09:24 PM
james_caza's Avatar
thanks tech
so if it passes both of those tests, then where do I go next?
is the exhaust gas test a gaurentee answer? where can I get a block test done?
Old Feb 21, 2010 | 10:43 PM
boxpin's Avatar
Sad to say, this is what mine did before it overheaded and died. Coolant pressure was the key that I ignored.
Old Feb 22, 2010 | 08:24 PM
Not a 100% on that but do that test and a compression test and that should tell you.
Alot of shops can do the block test.
mkmathis
Feb 16, 2008 07:03 AM
MJAlex
Sep 24, 2007 06:25 PM
rudykev
Jul 5, 2007 05:31 AM
defiant187
Jun 30, 2006 12:29 AM
LSE
Forum Issues
Mar 9, 2006 01:46 PM
