odometer stopped
Old Mar 1, 2009 | 10:01 PM
jareds4's Avatar
Default odometer stopped
just stopped yesterday every thing else works on the dash has any body had this problem were can i start to look does it have a cable that comes from the transaxle maybe unconnected thanks my peeps
Old Mar 1, 2009 | 10:08 PM
Somthngfrce's Avatar
This seems to be a common thing.. Mine is also not working. There's a gear that breaks inside the odometer.You can buy a new gear online or on ebay! Here's the DIY for the fix. http://www.matthewsvolvosite.com/odometer_fix.php
Old Mar 1, 2009 | 10:23 PM
JPN's Avatar
JPN
Default That is a common known problem
https://volvoforums.com/forum/volvo-850-16/how-repair-broken-oddometer-15644/
http://www.fcpgroton.com/product-exe...ategory_id/161
If you want to know the actual mileage even after the odo has stopped, you can get it from the ECU. IF 1993-1995, you can retrieve it yourself otherwise you can either visit auto parts shop to see if they can pull it for you or donate some $ at a dealer.
Here's a quote from MVS:
As long as you have the DTC boxes up under the hood ('93-'95).
1. Switch ignition on
2. Connect the fly wire to socket - A7
3. Push button 5 times
4. When LED comes on and stays on, enter code 1-1-1 as follows:
- press the button once when LED is still on
- wait for LED to go out and come on again
- read off response, which will be the last three digits of the odometer miles
5. Repeat steps #3-4, but enter code
1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
JPN
Old Mar 2, 2009 | 07:59 AM
Psaboic's Avatar
JPN nailed it. Follow the links to the info you need.
Old Mar 2, 2009 | 12:42 PM
jareds4's Avatar
Talking
thanks guys. i will try it. looks time consuming
but strait forward
my92940GL
Dec 28, 2015 04:22 PM
Will56
Aug 8, 2011 08:57 PM
kapka42
Jul 15, 2009 01:14 PM
Keith Tobberman
Sep 2, 2008 08:21 AM
markymarc1981
Jan 10, 2008 10:54 PM
