oil leak
i replaced the pcv system and now have a oil leak coming from the right front of the motor the only thing that i can think of that it may be is the hosethat contects the little black box thing mayb the little 1 inch hose that fits between the box and motor any ideas thanks guys
jared
jared
Was the car leaking oil before you did the PCV? If not, there has to be a hose loose or something. I would take the intake back off and check everything out. If it was, then you probably have a blow cam or crank seal on that side of the motor.
where does the other end go are they hard to change out is it just a clamp on the end
