oil leak on top
Old Feb 14, 2007 | 10:25 PM
huzzsaba's Avatar
Default oil leak on top
I have noticed that there is oil leakage on top of the engine around where the oil cap is. I keep wiping it and its there again when i open the hood the next time. Is it because of the rubber seal under the cap that needs replacing?
Old Feb 15, 2007 | 09:16 AM
JPN's Avatar
JPN
Default RE: oil leak on top
Hi,
Yes, the filler cap gasket on 850s are noted for leak. I change it at every other oil change. I buyit at FCP Groton and I believe one was 65 cents.
I hope this helps.
JPN
Old Feb 15, 2007 | 03:36 PM
huzzsaba's Avatar
Also how hrd is it change turbo seals? Is there any DIY of how to do so? Thanks for the above info.
Old Feb 15, 2007 | 10:11 PM
volvo4mula's Avatar
are you refering to turbo drain seals? If so it's quite easy on an 850.
All you have to do is remove the bracket holding the drain to the feed line. Remove the two 5mm allen bolts from the top of the line then carefully take a prybar and bend the feed line delicately out of the way. the turbo drain will pull back and out.
A little tip: glue the new gasket to the pipe before you put it back in place.
Old Feb 16, 2007 | 02:34 AM
JPN's Avatar
JPN
Hello again,
If you're referring to the turbo oil return line, try the following:
http://www.volvospeed.com/Repair/turborepairline.php
When I did mine, I used Permatex's most oil resistant black silicone RTV paste gasket on the seal ring. If this is what you're planning to do, make sure you get both the seal and the gasket for the return line.
FYI, a minor oil seepage from the turbocharger itself (on the bottom side) is normal and there's not much you should do to it.
Cheers,
JPN
dhodge
Sep 23, 2010 06:09 PM
pacificnw2011
Sep 5, 2010 07:42 PM
imon_2nd
Jul 23, 2010 02:50 PM
CassMori
Jun 19, 2009 07:13 PM
SuspTech
Jan 25, 2009 09:54 AM
