Oil Leaking from Oil Filler Cap
Old Dec 12, 2014 | 10:07 PM
mjg1664's Avatar
Default Oil Leaking from Oil Filler Cap
Is an oil separator the same thing as a pcv valve flame trap? I'm told I have oil separator issues but cannot find a part by that name.
Old Dec 13, 2014 | 06:23 PM
damien360's Avatar
Yeah the pcv box is an oil separator. I recommend replacing that alone with clean I the engine ports really well
Old Dec 14, 2014 | 01:12 PM
When was the last time the oil cap seal was replaced?
Old Dec 14, 2014 | 02:18 PM
damien360's Avatar
The problem lies with the pcv system which causes the oil cap seal fail.
Old Dec 15, 2014 | 11:40 AM
mjg1664's Avatar
Replaced it twice as I thought the first one might have been a cheap China replacement. It's definitely excess oil pressure causing the leak.
Old Dec 22, 2014 | 11:58 AM
tony1963's Avatar
The seal on the cap is a separate rubber piece. No need to replace the whole cap.
The oil separator and associated lines all need changing too.
volvoQ's
Jan 30, 2020 06:03 AM
Volvoguy505
Jun 6, 2018 03:10 PM
Riculus
May 28, 2010 12:08 PM
rgilius
Aug 12, 2009 10:55 AM
Invictus84
Sep 3, 2005 06:35 PM
