Oil leaking from the ol filler
Old May 24, 2010 | 06:05 PM
Riculus's Avatar
Angry Oil leaking from the ol filler
Hey Guys,
Whats up. I have problem. Oil is leaking out f the oil filler in y 95 850 glt. I replaced the cap wth a new one and still the same problem. Yesteday I started seeing blue smoke from the exhaust went I rev the engine.
Any help will be greatly appreciated.
Riculus.
Old May 24, 2010 | 06:29 PM
silkhope's Avatar
When was the last time you cleaned up, and changed out your PCV system? Search the threads if you need to find more info on this. Our cars do not have a traditional PCV valve.
Old May 24, 2010 | 06:48 PM
Riculus's Avatar
maybe 4 years or so ago. give or take a few months. How can I clean the PV if that is the problem
Riculus
Old May 27, 2010 | 03:02 PM
boxpin's Avatar
You should replace it, not clean it. Visit FCP for the kit.
Old May 27, 2010 | 08:56 PM
docmot's Avatar
You should also replace the gasket on the filler cap AFTER checking the PCV system. They get brittle and will fit loose after a while. That is not a bad thing because if the crank case pressure increases because of a clogged PCV system, it is better to blow off that pressure from the filler cap than damage a crank seal.
Old May 28, 2010 | 12:08 PM
boxpin's Avatar
+1 good advice.
volvoQ's
Jan 30, 2020 06:03 AM
Volvoguy505
Jun 6, 2018 03:10 PM
mjg1664
Dec 22, 2014 11:58 AM
floydy
Feb 11, 2006 03:15 PM
Invictus84
Sep 3, 2005 06:35 PM
