onboard computer
Old 08-09-2005 | 10:07 AM
fast850r's Avatar
Default onboard computer
OK. Another question(I'll learn alot by the time I'm done). I have a 95 850 with the computer readout under the speedo. Whenever I start the car, the only thing visible is the clock. I have to turn the switch w/reset button whenever I want to see something else like outside temp, or mpg. I don't have an owner's manual, so have no idea how it all works. Any help?
Old 08-09-2005 | 06:08 PM
Rand850's Avatar
Default RE: onboard computer
Wherever the switch is pointing is what display you should see, i.e. it the switch is pointing to temp, you should see the temp on startup. If not, then your ECM is fried or yourswitch is bad.
Old 08-09-2005 | 06:24 PM
fast850r's Avatar
OK Thanks. But what happens is, if I leave the switch on outside temp, next time I start the car there are just a bunch of dashes there, next to the clock. If I turn the switch, left or right, and back to temp, the temp is there. I thought it would be there whenever you start the car, not have to turn the switch to see it. Same for any other display out of the 6 or 8 there. When I start the car, it is just dashes. Didn't know if that was normal.
Old 08-09-2005 | 06:41 PM
JimKW's Avatar
Nope that's not normal. It should work just like you said. Sometimes it takes a few seconds to come on, but mine is almost always on outside temp and that's what I seel w/o touching the swicth.
Old 08-09-2005 | 06:56 PM
Rand850's Avatar
That is because the computer has to take a sample of the outside air temp several times before it displays the temp, now if it is always dashes after a few minutes then you have a problem.
Old 08-10-2005 | 01:09 PM
fast850r's Avatar
Thanks. So if all I have is dashes, a few minutes after the car has been running, how do I correct it?
Old 08-11-2005 | 01:35 AM
Do you loose all functions or just the temp?
Old 08-11-2005 | 02:04 PM
fast850r's Avatar
I lose all functions. Wherever I have the switch while driving, when I shut off the car and then come back, I have the time, but nothing else. I have to turn the switch for any display to appear.
xc60 owner
Canada, Over Seas & Elsewhere
07-20-2014 12:09 PM
rockspop
11-18-2010 10:18 AM
Striker
04-20-2010 09:13 AM
midlife crisis
03-30-2008 08:54 PM
S70driver
02-24-2008 11:59 PM
