Overboost
Old Oct 26, 2022 | 04:30 PM
1NAR's Avatar
Question Overboost
Hello! I have a 1995 Volvo 850 with upgraded turbo and injectors. I was wondering if I could use a manual boost controller to turn down the boost. I'm not sure if it would because it seems like it would only ADD spring pressure. If I recall correctly the car will refuse to go above 15psi right? When in drive it will stop itself from going above 3k RPM. Or would there be another reason for this?
Old Oct 28, 2022 | 10:35 AM
top boost really depends on your turbo model and ECU tune. As I recall a stock 850T tune with a 15G turbo goes about 10 PSI. What's in your car for the turbo, tune and waste gate?
Old Oct 28, 2022 | 06:37 PM
1NAR's Avatar
I'm sorry I know it's a vague question and it's because I really wasn't sure what to ask! However I was able to randomly stumble across the solution. Apparently the wastegate flapper was adjustable and way to tight, forcing the bypass closed for way to long! I bought the project car and personally have no idea what turbo is in it, but it's now running up and down the road perfectly fine on the stock ecu. (Weird.) As I find out more I'll post a detailed list of what was done and how the "project car to daily" is going!
tyler850t
Apr 24, 2015 08:31 PM
powertoweight
Jan 19, 2010 08:57 AM
turbo850wagon
Jun 29, 2009 05:53 PM
syclone50
Feb 22, 2009 10:33 AM
code33
Mar 8, 2006 08:20 PM
