overboosting issues
Old Jul 24, 2009 | 11:58 PM
Garry's Avatar
Default overboosting issues
hey peoples I'm new here, i don't have a Volvo but a good friend of mine has one and he isn't very computer literate.
Recently he has been getting some issues with is 850 T5r (1995, 5 speed)
He believe it's hitting boost cut. He's been in my car (which isn't a volvo) but he says it's the same when i used to hit boost cut.
Anyway we tested the wastegate actuator by blowing 10psi of air into the actuator and it moved. So we believe it could be the TCV or whatever that controls that. But how do you test it?
also is it a common issue with 850's overboosting?
any info would be greatly appreciated
thanks
Old Jul 25, 2009 | 12:14 AM
Check all the vacuum lines at the turbo.
Not common unless a vacuum line is bad. If he is hitting fuel cutoff then he is boosting 15.5 PSI.
Old Jul 25, 2009 | 01:23 AM
Garry's Avatar
any ideas where i should look?
Old Jul 25, 2009 | 01:46 AM
VJZ's Avatar
VJZ
Tell him to spend the $20 on new vac hoses (which you can get in reels at auto stores).
Replace all vac lines on the car.
Along with all other hoses.
It only aids to longevity, good sir.
Old Jul 25, 2009 | 08:17 AM
There is only 3 vacuum lines that go to the turbo.
Old Jul 27, 2009 | 08:03 AM
boxpin's Avatar
Replace them as instructed. This is good advice.
Old Jul 27, 2009 | 08:13 AM
Psaboic's Avatar
We had the same issue recently. It turned out to be the Turbo's boost control valve. An easy fix for under $50
Old Jul 27, 2009 | 08:33 AM
Garry's Avatar
i will replace the hoses, but if that doesn't help. How do you test/diagnose the turbo-boost control valve?
nealeas
Jan 17, 2014 08:18 PM
VJZ
Sep 2, 2009 05:03 PM
TurboVolvoEnthusiest
Jun 27, 2009 12:49 AM
alphaville
Apr 2, 2009 05:30 PM
