overheating help
Old Aug 21, 2013 | 06:52 PM
97850t5wagon's Avatar
Default overheating help
ok so I fixed the axle and car has been running great but last night my gauge said car was overheating it was in the red so I pull over engine is just normal warm but my fill thank is going nuts boiling steaming. so today I check t-stat and take it out to test but still get same problem fans on im lost
Old Aug 21, 2013 | 08:40 PM
oh yea car has timing belt water pump and all that done @129kmiles car has 145k
Old Aug 22, 2013 | 04:42 AM
ok did some test left car on in 100deg outside car stay reg in middle on gauge but after I drive for a few min and get into boost the fill thank starts boiling and steaming and losing water but only gets hotter when I hit boost around 12-14psi
Old Aug 22, 2013 | 07:03 AM
97black850's Avatar
it could be a head gasket. did you check your oil to make sure there was no coolant in it?
Old Aug 22, 2013 | 10:10 AM
oil is like new car runs great I don't know why it would have a blown head gasket car never over heated before but who know.anyone know how to do a homemade compression test
Old Aug 22, 2013 | 10:41 AM
boxpin's Avatar
The leak may be only exposed when under higher temps and pressure. If the expansion tank is swelling with excessive pressure or steaming you have combustion gases entering the tank. Blown head gasket.
There are three chambers on a head. Cylinder, water, oil. When a head gasket blows it does not mean that you are going to mix all three. You can just break from the cylinder to the water or the cylinder to the oil. So, thinking you dont have a blown head gasket because your oil is still clean is not an effective test. If you really want to know go to Napa and get the test that detects exhaust gases in the expansion tank. Its like $40 but will answer your question.
Old Aug 22, 2013 | 11:08 AM
97black850's Avatar
Boxpin: I know what you're saying, I just didn't want the OP to be driving it with diluted oil. I understand what you're saying about the chambers
Old Aug 22, 2013 | 11:27 AM
im going to just do a compression test and see if its a blown gasket im done with this car already put lots of money into it.so if anyone needs parts all be listing
Old Aug 22, 2013 | 03:45 PM
boxpin's Avatar
What is your location? I buy cars like this, fix them and sell them.
Old Aug 22, 2013 | 05:22 PM
Here is a test you can do but I think the compression will be good.
Pull all the plugs but one. Turn the motor over by hand. If you feel resistance (compression), move the plug to the next cylinder and crank it over by hand again. If you get to a cylinder that doesn't give any resistance, that is the cylinder that has the bad seal. My guess is that the bad cylinder isn't bad enough to have zero compression.
Old Aug 22, 2013 | 05:23 PM
Old Aug 22, 2013 | 05:29 PM
How long have you had the car?
Old Aug 22, 2013 | 07:46 PM
im in lncaster ca
Old Aug 22, 2013 | 07:47 PM
arond3-4yrs
Old Aug 23, 2013 | 01:21 AM
[QUOTE=rspi;363199]How long have you had the car?[/QUOTE
wouldn't the motor be really hot to if it was over heating. I was checking the rad bottom hose and it was only a lil warm and the top gets super hot
Old Aug 23, 2013 | 02:40 AM
  #17
Brick850's Avatar
The top hose will always be hotter than the bottom hose. The water comes from the engine via the top hose to the radiator, cools, then goes via the bottom hose back to the engine.
Old Aug 23, 2013 | 03:04 AM
  #18
why isn't my motor hot if its over heating the only thing hot is the fill tank thing the rest of my motor is normal and the car has never got into the red on the gauge i cut it off before
Old Aug 23, 2013 | 12:54 PM
  #19
All because you have a head gasket breach doesn't mean the car is over heating. Not sure what the temp difference should be but it shouldn't be that much. Maybe 30 degrees.
james_caza
Feb 22, 2010 08:24 PM
uniquemicro
Mar 4, 2008 12:18 PM
mrpyromaniac
Sep 29, 2007 08:18 AM
beardo265
Sep 27, 2007 09:24 AM
jktiffin
Jul 20, 2006 09:24 PM
