pls help if you know what is poss fix
hey ppl, i ran into a situation here..ok my batt had a bad cell and i had to jump once a wk then last time i drove it i found a fuel leak on the rear pass of the engine which i ran out of fuel..id like to fix myself i see the hard lines but does it bend w/soft lines???...now i have a new batt the car cranks i dont ever rem hearing the fuel pump and still don't also the climate control radio does nothing the dash is working so i can't find the fuel leak cause i can't start i read it could be the ECM but i hope not..anybody have this oddity PLS help I'm a wheelchair user and independence is everything..so you see the circle im in...
thanks for your input
If you have a good battery next thing to do is find out why you can't hear the fuel pump.
Have you checked out the fuel pump relay ??
https://volvoforums.com/forum/volvo-...p-relay-64044/
I don't recommend this paperclip trick for anything but testing or to limp home if it dies on the road.
http://www.matthewsvolvosite.com/for...ic.php?t=32386
