Power Antenna not working
Old Apr 18, 2009 | 09:47 AM
SJanas0993's Avatar
Default Power Antenna not working
I recently replaced my AM/FM/CD player with an aftermarket model (Pioneer) in order to have a front USB input for my iPod. I wired the new plug matching all the colors (green to green, etc.). The only wire coming from the bundle I didn't connect was the orange one as it was not previously connected. Everything works fine but my power antenna won't go up or down. I checked the fuse and it is fine. Does anyone know what I might have done wrong (e.g. which wire needs to be connected where?) Any advice would be greatly appreciated.
Thanks in advance!
Forgot to mention I have a 1995 Volvo 850 Turbo
Old Apr 18, 2009 | 10:31 AM
The wire from the aftermarket raio should have a blue or blue/white wire that feeds the antenna.
I forget what the color is for the car.
Old Apr 18, 2009 | 12:32 PM
SJanas0993's Avatar
Default Already connected
I already connected both the blue and blue and white wires from the radio to the same colors coming from the car.
Old Apr 18, 2009 | 01:10 PM
But is that where they are supposed to go on the car?
That's why I always buy the harness that plug into the factory plug.
It makes life 100% easier.
Old Apr 19, 2009 | 09:08 AM
Psaboic's Avatar
Pull the access panel for the power antenna in the trunk, and look at which color wires go to the antenna motor. Like Tech said, just because you connected the same color wires to each other doesn't mean that is where they are supposed to go
rspi
May 15, 2014 07:36 AM
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
BigAdam
Oct 21, 2008 10:01 AM
