Problem with front end
Old Dec 11, 2010 | 10:09 AM
962ym's Avatar
Default Problem with front end
I recently changed my front struts and springs but am still bottoming out on the driver's side. Is there any way that I can raise the front end? Thanks! '97 850 T-5
Old Dec 12, 2010 | 05:14 PM
VTBricked's Avatar
Something's not right if you're bottoming out on the driver's side.
Old Dec 12, 2010 | 10:29 PM
Henry10's Avatar
You need to check if the nut at the top of the shock is tightened fully. I had a similar problem on the passenger-side when I replaced the struts and had to re-do the job -- a lot quicker the 2nd time (maybe 45 minutes to 1 hour tops).
Old Dec 13, 2010 | 07:41 AM
gilber33's Avatar
are you bottoming out or just clunking? Did you replace the spring seats and strut mounts?
Old Dec 13, 2010 | 09:24 AM
fcpgroton's Avatar
Former Sponsor
You definitely need to go over your work and see if you missed something. You should not be bottoming out at all. It is not like your car is lowered or anything.
Old Dec 13, 2010 | 03:35 PM
boxpin's Avatar
What springs did you replace? Brand?
Wing0
Dec 13, 2013 02:39 PM
Bruno937
Mar 8, 2009 12:41 PM
Virginia Girl
Jun 14, 2006 10:42 AM
