question..
Old Jun 18, 2010 | 02:05 PM
boatmoter's Avatar
Smile question..
Hi all, I need a air pump off a volvo for a hot rod project Im working on, I need to know the location under the hood I will find the air pumps off 1990 to 1997 models.. Thank you..
Old Jun 18, 2010 | 02:17 PM
ibified's Avatar
What specific vehicle you are needing it for would help.....can you give any more info?
Old Jun 18, 2010 | 03:20 PM
vjaneczko's Avatar
On the 850's, it's installed under the battery tray. There's a small hose (apx. 1 inch in diameter) connected to the front of the airbox that runs down to the pump.
If you're looking at a different Volvo, I'd guess the setup is the same so look for the hose coming off the airbox and follow it around.
Old Jun 18, 2010 | 07:29 PM
boatmoter's Avatar
Thanks guys,it's not going on a volvo, just follow the hose,thanks again..
Old Jun 20, 2010 | 01:47 PM
boatmoter's Avatar
Default Update
Hi all,got the air pump off a 850,have it all hooked up,runs for about 10 seconds then shuts off, it will start back up in about 1 minute, is'nt this pump suposed to run all the time except at idle??
Old Jun 20, 2010 | 02:21 PM
vjaneczko's Avatar
Nope. The air pump forces air through the exhaust when the engine is cold in order to improve the heat-up time of the catalytic converter. My understanding is that it's mostly an emmisions improvement bit. FYI - when the air pump system fails, it throws a P0410 error via ODBII and will cause cars to fail emmisions testing.
It is designed to run without the key in the ignition. If you need it to run non-stop, I'm sure you've be able to rewire it with little effort.
But that makes me ask; if you're doing a hot rod project, why do you need an air pump that only exists to improves emmisions?
Old Jun 20, 2010 | 02:33 PM
boatmoter's Avatar
vjaneczko ........ using it to pull 4 inches of vaccum from the crankcase and routing it into a catch can for any oil it may pull to increase HP,and most ford rangers with a 5.0 installed have a crankcase ventalation problem,don't know why,this also helps with this problem
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
