Question on AC
Old Dec 11, 2008 | 12:43 PM
summit's Avatar
Default Question on AC
I have heard that volvo's should always have their AC system on so they will cycle still otherwise they can fail or leak...
Truth or myth?
Old Dec 11, 2008 | 12:49 PM
Default RE: Question on AC
Myth
They have problems with some parts of the A/C and it is going to happen no matter what.
You can keep it off all you want.
If you work by theory then the system should last longer the more it is off. The pressure in the system would be lower with the A/C off.
When it is on the High side pressure is around and over 250 PSI when running low pressure is between 30 to 50 PSI.
Of it pretty much settles at around 50 PSI or so.
Old Dec 12, 2008 | 08:17 AM
Psaboic's Avatar
Myth. They are no different then other AC systems
Old Dec 12, 2008 | 10:37 AM
outdoor7or24's Avatar
Maybe the cycling thing you heard about is so the seals stay lubed... I have heard this before as well.
Old Dec 12, 2008 | 01:34 PM
summit's Avatar
Yeah it was for cycling them that I heard it. But it sounds like its the theory of dont use it cause it might break. (Duh, OR it might break if you dont use it. It was built therefore it might break)
Old Dec 13, 2008 | 09:50 AM
JPN's Avatar
JPN
But if you set the defrost, the A/C compressor kicks in automatically. This applies to the ECC (Electronic Climate Control) but not sure on the manual control type.
JPN
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
