quick few questions
Old Sep 18, 2009 | 07:49 PM
s_moneh's Avatar
Default quick few questions
hi guys i have a few quick questions, these might sounds dumb aha
-how do i know which turbo my 850 has in it?
i'm pretty sure i have a T5 ( my registration says i have a t5 but i jsut wanna know a way to tell)
-whats the difference between the regular 850 turbo and between the 850 R turbo?
-wheres the wastegate located on a stock 850 turbo?
Old Sep 18, 2009 | 08:10 PM
gilber33's Avatar
Search. This thread is about 10 below this one.
https://volvoforums.com/forum/volvo-850-16/i-have-few-questions-about-850-a-34424/
If you have an 850 turbo, then it's a 15G, if you have an 850 GLT, it's a 13G starting in 96/97, otherwise the GLT's didn't have turbos.
The wastegate is located on the exhaust housing.
Old Sep 18, 2009 | 09:50 PM
s_moneh's Avatar
ahhh my bad its my first time here, thanks
is the wastegate easy to be accessed to?
Old Sep 18, 2009 | 10:02 PM
gilber33's Avatar
fairly easy. Why do you need to access the wastegate?
Old Sep 19, 2009 | 06:55 AM
S70driver's Avatar
If your planning to adjust the WASTEGATE to increase the BOOST. DO NOT DO THIS. Yes you may have done this on other cars, other people may have done this on other cars and on Volvo's or someone told you you can do this to a turbo car.
Yes their all right, but in reality this is the worst method for increasing boost. Especially if you don't have a real boost gauge hooked up to the car.
If this is why you want access to the WASTEGATE please DON'T DO IT. To raise boost properly get an ECU upgrade and if you don't want to go that route then at the very least use a Manual Boost Controller (MBC). But even with these two methods a BOOST gauge is really important. Especially with a MBC.
Old Sep 19, 2009 | 08:19 AM
gilber33's Avatar
+124 to S70driver. Don't do that if that's what your thinking about.
Old Sep 20, 2009 | 12:03 PM
s_moneh's Avatar
aha yea actually a buddy of mine had told me i could do this, and i am doing the works, boost guage, mbc, bov, everything so i just thought the wastegate would be a great addon, but i guess not, so i may just stick to the 3 things i plan on doing for now.
my only other question is where exactly can i hook up the BOV? i have no idea where it could go....
Old Sep 20, 2009 | 12:15 PM
gilber33's Avatar
I would just do the MBC and boost gauge. The BOV is completely pointless, the only thing it will add is noise, the CBV does the exact same thing as a BOV. But if you really want to add a BOV it goes anywhere between the turbo and the throttle body.
The only reason you should ever be messing with the wastegate is if you add a BOV, then you should get a blanking plate to remove the CBV.
http://volvospeed.com/vs_forum/index...valve-threads/
Old Sep 20, 2009 | 01:33 PM
s_moneh's Avatar
alrite i got you, antoher question wats a safe boost level i can raise up to without worrying about much? and i would assume to figure out what my stock boost level is, is to install a boost guage first then go from there?
Old Sep 20, 2009 | 01:40 PM
gilber33's Avatar
The stock boost level is about 9-10PSI controlled by the ECU. Fuel cutoff is at 15PSI, most people who put MBC's on their stock 850 Turbo's usually set them to about 13/13.5. That will leave room for boost spikes. The 15G is out of efficiency at 15PSI anyways.
Old Sep 20, 2009 | 01:57 PM
s_moneh's Avatar
ahh ok, is the 15G low or high pressure?
another random question, how do i know for sure if i have the 850 platinum edition?
Old Sep 20, 2009 | 02:05 PM
gilber33's Avatar
15G is a HPT on the 2.3L engine. They didn't have the LPT option until 96/97, that was the 13G.
Is your car Pearl?
Old Sep 20, 2009 | 02:07 PM
gilber33's Avatar
Is it this color?
Old Sep 20, 2009 | 02:15 PM
s_moneh's Avatar
aha yes its pearl, so i'm going to assume its the platinum edition?
Old Sep 20, 2009 | 02:16 PM
gilber33's Avatar
Then, yes, it's the Platinum Edition.
Old Sep 20, 2009 | 02:21 PM
s_moneh's Avatar
would you know of any good places to buy a-pillar pods? i would need it to match the grey interior and i cant find any apillar pods anywhere
Old Sep 20, 2009 | 02:26 PM
  #17
gilber33's Avatar
http://www.ipdusa.com/Volvo-850/Perf...2-143-148-445/
Artunc
Aug 29, 2010 06:27 PM
rbgCODE
Jan 12, 2010 11:47 PM
CyDetrakD
Aug 30, 2008 01:54 PM
losboricua
Jan 25, 2007 04:28 PM
t.d.
May 29, 2006 11:47 AM
