quick question
Old Oct 28, 2007 | 09:57 PM
volvodrummer's Avatar
Default quick question
where is the rpm sensor located?
Old Oct 28, 2007 | 09:58 PM
Default RE: quick question
i have a '93 glt.
Old Oct 28, 2007 | 10:05 PM
RedTurbo850's Avatar
It's also called the Crankshaft position sensor also (can be said interchangably)..
the camshaft sensor is right under the upper motor mount and is held in by two T45 torx bolts. and the RPM sensor is hidden further below that a little to the left and held in by one 10mm bolt..
if you take the air box out and look behind the coolent hose it will be right where the engine mounts to the tranny. its only one 10mm bolt..
colgate41
Oct 12, 2006 09:41 PM
tomservo
May 16, 2005 12:36 AM
eurochick
May 10, 2005 01:27 AM
jaz
May 7, 2005 12:59 AM
volvobacon
Apr 17, 2005 01:24 AM
