Radiator problems that will mix fluids...
Old Oct 23, 2011 | 11:34 AM
Smile
Originally Posted by rspi
On another note, I'm still stumped on how a radiator can transfer fluid. How in the world does the coolant leak into the tranny section of the radiator? I'm really blown away by that. Is this an after market radiator or oem? How does that happen?
I'm surprised you're surprised. The radiator on a Turbo has both an engine oil cooler and transmission oil cooler inside it. They are like small radiators themselves and can either corrode and develop a pin hole leak or have a seam loosen. The engine oil cooler is inside the passenger side of the radiator and the transmission cooler is on the drivers side. Each side has two hoses leading to it, one in and one out. Depending on pressure and temperature you can get almost any mix of engine oil, transmission fluid and coolant between the three. It can fool you into thinking you have a bad head gasket when actually it's coolant being pushed into the oil cooler and then to the pan after the engine is shut down and there's pressure in the coolant and not the oil. Leaking the other way you can get engine or transmission oil in your expansion tank.
Old Oct 23, 2011 | 02:10 PM
Ok, I do realize that these cars have a radiator that carry 3 fluids but why would Volvo engineers design a system that would ever risk the possibility of mixing these fluids when any mix of these fluids would cause serious damage to the car? I an only imagine that the coolant lines are seperate from the oil lines and the tranny lines. So what people are experiencing is a failure of the coolant side as well as the oil or tranny side which causes the fluid to mix. That is a heck of a failure.
I read where a guy put a radiator in his 960 and had coolant mix with the tranny right away. Destroyed the tranny. I just assumed that the company that made the radiator blended the lines somehow. This is really crazy.
Old Oct 23, 2011 | 09:34 PM
Wink
Nope, it's been done forever and by almost all car companies. If it has an automatic it almost always has a cooler built into the radiator and depending on the quality, it can leak at some point. Some of the 4X4 and vehicles that are commonly used to tow may have an engine oil cooler but they are rarer.
I was surprised with my RX-7 as it was one of the few cars I've come across with a factory trans cooler separate form the radiator.
First photo, cooler in an end cap. Second it different styles of coolers inside the radiator.
Attached Thumbnails Radiator problems that will mix fluids...-oil-cooler-inside-end-cap.jpg   Radiator problems that will mix fluids...-auto-part-oil-cooler.jpg
The Space Monkey
Jul 12, 2017 11:52 PM
960wagongreen
Jan 16, 2012 09:36 PM
holtmant
May 31, 2007 01:58 PM
azeezn
Nov 2, 2005 08:36 PM
blase
Jul 29, 2005 01:03 AM
