radio code problem
Old May 22, 2007 | 07:51 PM
white out's Avatar
Default radio code problem
So I screwed up my code and the radio displayed "off". I disconnected the radio and let it sit in the car for a few hours. Re-connected the radio and powered it up. Still get "off". So I disconnect the positive power cable on the battery for two hours. Re-connect it and the damn radio still says "off". How do I get it back to where I can enter the radio code?
Nick
Old May 22, 2007 | 09:21 PM
RedTurbo850's Avatar
Default RE: radio code problem
If disconnecting the battery doesn't work, I have no clue.
Call the dealer and ask?
Old May 22, 2007 | 11:29 PM
JPN's Avatar
JPN
So I believe you can turn the volume control **** all the way to the left and then turn it on again and enter the code (unless you already tried it)?
JPN
Old May 23, 2007 | 03:53 AM
JPN's Avatar
JPN
Just found the following at Matt's site:
If your radio says OFF, leave the ignition on *in the first position for 2 1/2 to 3 hours in order for it to display CODE. Or, as forum member Rhett says: In my 1996 850, I can clear the OFF state by pulling the fuse for the radio (#7 in my car). That's a bit simpler than leaving the ignition in I for a couple of hours -- particularly if you don't have a garage.
*Not sure if they really meant the 1st detent or the 2nd-ACC.
http://www.matthewsvolvosite.com/radio.php
If it still doesn't do the trick, try pulling the radio out (press on the slim long tabs on the sides of the unit), disconnect the connectors and re-connect them to see if it gives up to your commands. If thisdoesn't do, have a visit tothe dealer.
JPN
Old May 23, 2007 | 05:35 AM
J Telectro's Avatar
Hi Kanji and white out,
I tried removing fuse 7 a couple of nights ago and it worked great.
I did have to wait a minute or two before replacing the fuse but
that was a lot better than disconnecting the battery or waiting 2-3
hours with the ignition on.
My car is a 96 also.
John
Old May 23, 2007 | 07:02 AM
JPN's Avatar
JPN
Hi John,
I believe it would also work for white out, and I'm sure he would appreciate it.
I was kind of surprised that the radio was made in Japan (Alpine?), because it didn't look as good, but it was made during the early 90s so that was probably why.
BTW, what time do you wake up in the morning? You seem to post replies sometime between 5 & 6am, which is about 5 to 6 in the evening across the Pacific. Just curious.
Thanks,
Kanji/JPN
Old May 23, 2007 | 11:49 AM
white out's Avatar
Thanks for your help guys. I will check out that #7 fuse after work tonight.
Nick
Old May 23, 2007 | 11:16 PM
JPN's Avatar
JPN
May the force be with you.
JPN
Old May 24, 2007 | 03:22 PM
white out's Avatar
#7 fuse didn't work. I had to use the ignition for 2 hour thing. But it works fine now.
Nick
Old May 24, 2007 | 07:13 PM
J Telectro's Avatar
Nick,
Good work. Congratulations!
Kanji,
Yeah, I'm usually up at 5am. It's the only time I have to
get on the forum. The problem is that I'm usually more asleep
than awake when I post. Many times I look at my previous
post and ask "wow,did I really write that?...I must have still
been asleep."
I didn't know that radio might be an Alpine. Good to know.
Best regards,
John
Old May 24, 2007 | 10:40 PM
white out's Avatar
Alpine ftw!
karatechop22
Aug 5, 2013 01:13 PM
cbgav
Sep 10, 2007 05:25 PM
jayb
Aug 27, 2004 09:29 PM
