Rear Brake and A/C noise
Old Oct 9, 2005 | 03:44 PM
Mass850's Avatar
Default Rear Brake and A/C noise
Hi,
Having tightened the adjusting Torx screw in the console as far as I could, I have been unable to create any resistance at the brake lever. In additon, I notice a slight squeak fron one rear wheel, which goes away if I pull the brake lever up and down.
Supposing for a minute that the rear shoes require replacement, the rotors don't look that wonderful either, anybody have a ball park idea on the cost of this job?
Also, I notice a slight noise when I have the AC on, from under the hood, it is a cylical noise, going on and off. The AC is working and cold at the moment, but is this impending doom, or, for that matter, does it sound like something common I can address?
Thanks in advance.
Old Oct 9, 2005 | 03:48 PM
Default RE: Rear Brake and A/C noise
Not exactly sure about the price for the brakes.
For the A/C either you are low on freon or you had the blower motor at a low fan speed.
It will cycle when low on freon.
But it will also cycle if you have the fan speed low to prevent the system from freezing up.
Old Oct 9, 2005 | 07:26 PM
Mass850's Avatar
Perfect diagnosis!!
Recharged the system, noise has completely gone!!
Thanks once again Tech!!
Have a great night!!
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
agardin10
May 22, 2011 10:52 AM
enoble
May 29, 2010 03:51 AM
booyaolian
May 24, 2008 01:37 PM
jcmartin
Dec 6, 2006 08:26 PM
