Rear Brake Noise -- Half Shims Are the Fix
Old Nov 30, 2006 | 05:19 PM
jcmartin's Avatar
Default Rear Brake Noise -- Half Shims Are the Fix
For rear brake squeal, squeak, using metal shims that only cover 2/3 of the pads is the solution. I tried every combination of grease and brake quiet on the market. Even went so far as to change pads and have the rotors resurfaced.
JM
Old Dec 2, 2006 | 01:12 AM
JPN's Avatar
JPN
Default RE: Rear Brake Noise -- Half Shims Are the Fix
Hello JM,
I used cv-joint grease on the rear in August and so far they are quiet. But yes the shims are of 2/3 type, Scan-tech Sweden. Typical brake-quiet compound didn't do any good, as you've stated.
Thanks for the info.
JPN
Old Dec 5, 2006 | 08:58 PM
jcmartin's Avatar
As it turns out, the CV joint paste and OEM pads didn't work either.
Time to sell the car.
JM
Old Dec 6, 2006 | 08:26 PM
If the rotors were turned that is most likely causing it.
Volvo's don't like to have the rotors cut.
colt1911
Jul 10, 2010 07:01 AM
Miatamon
Apr 11, 2007 03:38 PM
hfs
Dec 17, 2006 10:20 AM
jcmartin
Nov 26, 2006 12:28 AM
