Rear control arm. Delta link tool anyone???
Old Sep 14, 2018 | 06:31 PM
860ARE's Avatar
Default Rear control arm. Delta link tool anyone???
hi. My volvo 850R has blown out rear trailing arm end links. Im looking to know if anyone around southern NH has tool number 9995497. Just to borrow... Please help a volvo DIY guy keep his car on the road another 300,000 miles. Thanks.
Old Sep 15, 2018 | 03:07 AM
tony1963's Avatar
And some here say that the newer Volvos cant go the distance.....
Old Sep 15, 2018 | 06:49 AM
860ARE's Avatar
They cant. Mine is a 96
Old Sep 15, 2018 | 07:24 AM
tony1963's Avatar
No, I was referring to those that think the 240/740/940 were the end of the Volvo line. I guess that I count yours as a modern Volvo compared to those relics.
Old Sep 15, 2018 | 07:33 AM
860ARE's Avatar
Ohhh gotcha. Im creeping up on 350,000 Odometer broken. Just did full headjob exhaust valves head gasket and everything else in there. Runs great. Car is from Maine. Seen alot of winter ****.. just need to get those endlinks replaced....
Old Sep 15, 2018 | 08:59 AM
tony1963's Avatar
I would be willing to bet that the compression is within 95% of OEM even after that mileage. Very little wear ever on the piston rings and walls if you do proper oil changes, which I'm sure that you have.
Old Sep 15, 2018 | 01:00 PM
860ARE's Avatar
I had one blown valve and one almost burnt. Now all 10 new. Bottom end and tranny all original..👍
Old Sep 15, 2018 | 04:45 PM
regarding the delta links, they slide into the transverse arms but have a plastic sleeve that makes them tough to pull back out even when you have the bolts removed. You have three options - 1) buy the puller (IPD sells one for about $225) 2) use a drill to poke holes in the plastic sleeve to allow you to pull it out with a make-shift puller 3) heat with a torch enough to melt the plastic. I'd also recommend for northern cars to inspect the bolt that goes into the chassis as they can rust and you may need to weld solid again.
Some reading:
https://www.matthewsvolvosite.com/fo...?p=31294#31294
Old Sep 15, 2018 | 06:05 PM
860ARE's Avatar
I was going to make a Home made puller if I can’t find one. From what it looks like in the photos is a hollow peg it comes out of the chassis and then bushing slides over it in the bolt goes up through it? How would i know it’d rusted out up inside
Old Sep 18, 2018 | 09:01 AM
Its really a very simple design. From what I recall, there are only two bolts - one to the chassis and the second which goes through the transverse arm. the transverse arm is just a hollow slot for the bushing to slide into and there's a plastic sleeve that goes between the bushing and the arm to ensure a tight fit. So first you need to remove those two bolts, let the arm hang down then the work begins for separating the two. I don't think the issue is whether its rusted up inside (since there's plastic between the arm and the bushing) - its just a compression fit that requires a puller to separate. That's why you can try drilling holes in the plastic to make room or using heat to melt the plastic to loosen the fit.
Old Sep 18, 2018 | 11:23 AM
860ARE's Avatar
Im going to try cut up a coil sprIng compressor and make a puller and then heat and drill. Thanks man
Old Sep 18, 2018 | 01:08 PM
tryingbe's Avatar
Big Blue is no longer available.
https://www.matthewsvolvosite.com/vo...ig-blue-loaner
Old Sep 18, 2018 | 02:08 PM
860ARE's Avatar
Damn... I found this photo online. I’m gonna try to re-create it.
Old Sep 18, 2018 | 04:05 PM
tryingbe's Avatar
Might be easier just to buy that tool.
9995497 Rear Axle Outer Bushing Press Tool
Old Sep 18, 2018 | 09:13 PM
860ARE's Avatar
Hmm that one is much cheaper than IPD. Maybe i will. Thanks
860ARE
Oct 15, 2018 08:23 AM
Ajae
Apr 16, 2018 08:41 PM
860ARE
Mar 25, 2018 08:20 AM
Joe.
Aug 8, 2017 09:03 AM
Greg150
2001-2013 model year XC70
Jul 5, 2014 11:46 PM
