rear main seal, where is it? anyone have pics?
Old Oct 29, 2008 | 08:39 PM
chef's Avatar
Default rear main seal, where is it? anyone have pics?
Hi guys,i know many of you have talked about the infamous "rear main seal", i just wanted to know where exactly is it located? if you have any pics it would help.thanks
fabs
Old Oct 30, 2008 | 08:15 AM
Default RE: rear main seal, where is it? anyone have pics?
Sorry no pics the transmission has to come out to get to it.
Old Oct 31, 2008 | 11:30 PM
bestharry's Avatar
Hi there,
I just d\i\d the rear main seal on my 96 850 and all i can say is that its not a too bad of the job provided you have sufficient equipment/tools and some physical help. It took me 2 days to finish it with few nominal damages but i m very happy to see no more dripping under the car.
Old Nov 1, 2008 | 05:17 AM
JPN's Avatar
JPN
FYR.
The pics are a courtesy of Robrike; Master of the RMS.
JPN
[IMG]local://upfiles/6892/EBD1C11E66D64162A01F721AFAF8EEAE.jpg[/IMG]
[IMG]local://upfiles/6892/B3043AA8C1224FE397FAEA37BAC393D9.jpg[/IMG]
Old Nov 1, 2008 | 10:44 PM
chef's Avatar
Hi Guys
JPN..thanks for the pic...(kinda krindging...)...i think i may have a bad seal...I was just snapping some pics of where it is leaking...let me know if it's that...
[IMG]/image]
[IMG]/image]
Here is a closer shot of the surrounding are:
[IMG]/image]
[IMG]/image]
IF it is this, what are the effects/symptoms? is this why i'm loosing oil? I don't have the smoke coming out of the dipstick, and not much smoke at startup...occasionally get apuff but much less...and the exhaust smell is not as bad as it used to be.
Also can i still drive the car like this? will it eventually kill the engine?
thanks
fabs
Old Nov 1, 2008 | 10:45 PM
chef's Avatar
just a note....i'm not consuming tranny fluid...the fluid seems to be in good shape, not sticky or stinky.thanks
fabs
Old Nov 2, 2008 | 05:59 AM
That looks like a Cam seal might be leaking and running down the back of the motor.
If you look where the tranny meets the motor there is a slit almost where those 2 screws are by the mount. If it was running out the slit that would be the rear main. That looks like it is a little higher and running down.
Old Nov 2, 2008 | 07:23 AM
chef's Avatar
Hey Tech, how are you? i'm not sure if it is the sear or a cam seal...basically it's dripping from where this shaft is..the shaft goes towwards the passanger side of the car , where it looks exactly the same as this pic, but it's not leaking on the pass. side. just the drivers side...if it is the cam seal, what are the effects? can i leave it like this? thanks
fabs
Old Nov 2, 2008 | 07:50 AM
You can leave it for a little while as long as you keep an eye on the oil level.
If it was the rear main it would be coming out of the middle of the area under the car where the tranny meets the engine. Not really by the axle.
I am doing ok I guess.
Old Nov 2, 2008 | 01:34 PM
bestharry's Avatar
This looks like a leaking axle seal and it should be a very easy job to do (as compared to R Main Seal). But this will not result in loosing engine oil but might be hitting on tranny fluid. But from the pics it looks like a very small leak to do any noticeable fluid loss but you can drive it without any worries for as long as you want butshould check the level every week or so.
oreng
Jul 20, 2010 03:22 AM
jcmartin
Sep 20, 2008 09:19 PM
erickfredrick
Apr 30, 2008 08:17 PM
850Sleeper
Oct 3, 2006 09:16 PM
anubyss
Nov 2, 2005 11:47 AM
