rear o2 sensor protective plate bolts
i have a 95 850 and i'm changing the rear o2 sensor. while loosing the bolts on the plate below the sensor the bolts went loose after one and a half turns. how can i remove them and then tighten them? the wire to the sensor is under the plate. it seems like the nuts were welded down and the weld broke. can i reach the nuts from under the rug in front of the seat? any help would be great!!!
mjinnj
mjinnj
I really do not understand what you are asking but here are my instructions for replacing an o2 sensor:
O2 Sensor on a 1995 Volvo 850 T-5 replacement instructions
I am assuming he is. Sorry dude but it's die-grinder time!! Get in there with a cut-off wheel and take the head of the stripped/seized bolt off. Worst case you could leave that plate off but wouldn't recommend it.
dads 740 turbo
10-18-2008 09:12 AM
ropay1965
10-20-2005 12:50 AM
