rear spring replacement
Old Apr 30, 2005 | 02:27 PM
moet32's Avatar
Default rear spring replacement
I am trying to replace the rear springs on my 850
when i try to remove the lower retaining nut the whole bolt and nut rotates
any idea how to stop this happening
any help would be welcome
thanks
steve
Old May 1, 2005 | 01:55 AM
Default RE: rear spring replacement
There is supposed to be a tab there to hold it into place.You will have to find a big pair of channel locks or something like that to hold it while you loosen the nut.Also if the tab is snapped you might be able to stick a screw driver in both holes once you line them up to hold it.
Look at the other side and see if the tab is still there so you know where it is.
paul1149
Sep 6, 2012 11:20 AM
ludeless
Oct 30, 2011 07:02 PM
twowheelin
Jun 2, 2008 10:34 PM
blackstarpower
Jan 5, 2007 12:26 AM
blackstarpower
Dec 31, 2006 09:19 PM
