Removing the intake
Old Feb 26, 2010 | 04:38 PM
brianb's Avatar
Default Removing the intake
Hey guys...I need to replace my starter and it sounds like the best way to get at it is to remove the intake. It looks like it's just a couple bolts on the engine block to remove it. Is there anything I need to be aware of when I remove it? Is there a gasket I need to replace? Also, Does anybody have any pics of a starter replacement? Thanx
Old Feb 26, 2010 | 05:07 PM
JimKW's Avatar
Go to the Frequently Used Thread which is a sticky at the top. Look at the PCV one and it will tell you how to remove the intake manifold with pictures. Not sure I've seen anything on the actual starter though. Once the intake is off, I think it should be pretty straight forward though.
Old Feb 26, 2010 | 06:25 PM
confused_al's Avatar
It is easier if intake is removed, normal way to do it is to remove the fan shroud. There is a support bracket, for the old type of starter needs to be unbolt as well.
Old Feb 26, 2010 | 07:29 PM
gdog's Avatar
Pulling the fan/shroud assembly is less work than pulling the intake manifold. Once out of the way it's pretty straight forward...
Old Feb 27, 2010 | 02:05 PM
brianb's Avatar
Thanx guys...My starter is getting very noisy and sometimes seems as it doesn't quite have enough to turn the engine over. I think it's definately on borrowed time.
Old Feb 27, 2010 | 03:16 PM
JimKW's Avatar
Sure it's not just your battery? In me experience starters either work or they don't.
Old Mar 1, 2010 | 11:48 AM
brianb's Avatar
Yes, the battery is a few years old but, I do have a battery tester and it shows as ok. The starter itself is a bit noisy and the maintenance records show, from the previous owner, that the starter may need to be replaced soon.
Jono
Oct 24, 2013 09:57 PM
coleman
Jul 6, 2010 09:12 AM
rquinonez32
Sep 30, 2008 02:08 PM
JBVolvo
Apr 6, 2007 10:17 PM
