Replace Ignition 1995 T-5R
Old Nov 28, 2015 | 06:24 PM
Rick Almeida's Avatar
Default Replace Ignition 1995 T-5R
I want to replace my ignition on my 1995 850 T-5R.
I am having problems wit my cluster sometimes working sometimes not. Not
long ago my gas gauge, speedo, and tach weren't working. I replaced the VSS and PNS and that solved some of the problems. When I start the car I turn the key on, start the car, then I have to turn the key back a hair or I can't shift it out of park. The cluster lights will stay on also. I figure replace it now before It fails completely. I was also told that the electrical portion of my ignition switch was bad. What do I need to buy for parts to fix the problems.
Do I need the parts below or others.
THANX Rick
iPd+
112425 - Ignition Electrical Switch
120870 - Ignition Cylinder Tumbler With Keys
Old Nov 30, 2015 | 06:00 PM
boxpin's Avatar
I think you need the ignition switch but not the tumbler w/key. The ignition switch is the spring loaded part and will control where the key position ends up. Its a super simple job to replace the switch.
bobmason
May 14, 2015 12:26 PM
foodmonster
Feb 12, 2013 12:47 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
syncro
Nov 9, 2008 08:14 PM
