Replaced engine, still low HP
Old Aug 24, 2006 | 01:47 AM
jcmartin's Avatar
Default Replaced engine, still low HP
When last I posted, I was in the process of having a 1997 70K mi S70 engine put into my 1995 850. The transplant was successful. New Bosch rotor, cap, plugs and wires, all new fluids. Good compression -- within spec for a car with less than 100K.
The problem I am having is acceleration. The car is as slow as it was when the original engine went. Put on the AC and acceleration over 60MPH is a joke.
What would you check and replace first? Can you help me prioritize by effort and cost? (I'm doing the work myself)
Fuel filter and pump -- Is fuel delivery a common performance problem?
Injectors -- Does it make sense to replace them? Clean them? Bosch only?
Throttle body -- My Saab needed it cleaned constantly. Should I attack the intake? If so, what pieces should be cleaned or replaced?
General cylinder and valve carbon -- Seafoam thru the intake? It has been a lifesaver for emissions inspections.
Sensors -- Is it possible that the O2 sensor, and all of those various gizmos, could retard the engine?
Transmission -- Anything there that needs particular attention? Is it beliveable that the transmission is eating HP?
Fluids -- Tranny, differential, oil. Could they really cause lag?
Volvo-ness -- I've never driven a non-turbo Volvo with much pickup. Am I just expecting too much from a ten-year-old car? Strangely enough, it is my daughter who is complaining; my son drove it for two years and was cool with it. Of course, he was the one whole let the oil get low and fried the engine. Parenting is always a surprise.
Thanks in advance,
JM
P.S. Just so you understand, I am not so much expecting the car to be a rocket. I don't WANT the car to be a rocket since my sixteen-year-old will be driving it. I just want to make sure that I'm getting good efficiency from the beast.
Your expertise is appreciated.
Old Aug 24, 2006 | 08:28 PM
Default RE: Replaced engine, still low HP
It was Non-turbo correct?
Is there good flow from the exhaust?
Old Aug 25, 2006 | 11:42 AM
B1mmer's Avatar
I would be checking the cat flow. I would think you would be throwing check engine lights like crazy if it were, but a clogged cat would definitely hurt acceleration. - AB
Old Aug 27, 2006 | 12:30 AM
jcmartin's Avatar
Default Maybe I'm expecting too much
The car is a '95 850 with an '97 S-70 non-turbo engine. I can get into traffic with a roughly 10 second 0-60 acceleration time. Once at 60 MPH, I can only get to 70 with any dispatch if I push the accelerator enough to downshift.
Just seems very slow, that's all. As if I had only 100 HP. Is this just what the engine is capable of producuing?
JM
Old Aug 27, 2006 | 12:44 AM
jcmartin's Avatar
Default So what cat should I use for a replacement?
If I find that the converter is clogged, what should I replace it with? There are several direct replacements that include the oxygen sensor port in the $200+ range, and several others that are universal without the O2 sensor in the $60 range. Should I try to find a hi-flow cat for this model?
Thanks,
JM
Old Aug 27, 2006 | 12:09 PM
Default RE: So what cat should I use for a replacement?
You could find a high flow. But try to get close to the $200.00 one.
I have heard of people having problems with the Universal ones.
Old Sep 3, 2006 | 01:54 AM
jcmartin's Avatar
Default So if it's the Cat, how do I test?
So, assuming that my wweak engine problem may be the catalytic converter, how do I test that theory? Is there a way to assess the flow or pressure drop through the cat?
Thanks,
JM
Old Sep 3, 2006 | 10:08 AM
Default RE: So if it's the Cat, how do I test?
About the only way to tes would be to drop the exhaust and see if there is a difference.
Old Sep 3, 2006 | 11:17 AM
rp850's Avatar
Have you checked the ECU for any codes?
tork
Jul 16, 2010 11:43 AM
tenchu
Apr 20, 2008 12:17 PM
ocean238
Dec 23, 2007 05:43 AM
jayturk99
Sep 17, 2007 07:14 PM
GearHeadKS
Sep 10, 2007 05:56 PM
