Replacing the Indicator
Old Dec 12, 2011 | 01:13 PM
QueenT's Avatar
Default Replacing the Indicator
Hello, I am new to this Volvo Forum and I need my fellow Volvo lovers help. I indicated to change lanes and the indicator snapped in my hand. I need some advice on how to remove the front cover of the steering wheel and how to replace the indicator. Thanks
Old Dec 12, 2011 | 09:27 PM
swiftjustice44's Avatar
what is the year and model of your car? I'm assuming it is a Volvo...
Old Dec 13, 2011 | 08:35 AM
QueenT's Avatar
My car is a 1995 Volvo 850
Old Dec 13, 2011 | 10:17 AM
Remove the steering column covers. You will have to remove 2 T-15 screws in the front part of the cover. You will need it to be long to reach the screws. That will remove the top cover. Note be careful removing the T-15 screws. Hold down on the top cover while removing then or the tabs might break off the top cover. Then remove the 2 T-25 screws and remove the lower cover.
Next remove the turn signal switch, it is held on by 2 T-25 screws.
Old Dec 13, 2011 | 09:20 PM
QueenT's Avatar
Thanks rspi I will let you know how it worked out for me.
Old Dec 14, 2011 | 12:06 AM
gdog's Avatar
Don't you need to pull the steering wheel too? And if you're going to do that, make sure you disconnect the battery so as not to set a SRS code...
BTW: where's GTA?
daisyifyoudo
Oct 29, 2005 05:19 PM
migkam
Sep 28, 2005 01:15 AM
jimny33
May 7, 2005 11:03 AM
stevehill
Mar 18, 2005 06:41 PM
jdbs3
Nov 16, 2004 11:42 PM
