right washer dispenser
Old May 19, 2005 | 11:36 AM
Geetarslim's Avatar
Default right washer dispenser
Hello,
My right side (looking out from inside the car) washer dispenser won't work, the left (driver side) one works just fine. Is the line clogged? Please help.
Thank you and have a Great Day...
Old May 19, 2005 | 11:47 AM
Default RE: right washer dispenser
1ST make sure it isn't clogged.Then look at the Valve inline on the underside of the hood.
Old May 29, 2005 | 10:09 AM
Geetarslim's Avatar
It isn't clogged, or It doesn't appear to be. Also I noticed that the dispenser fills up with just a little bit of fluid, I barely put in 3 cups and it fills close to the top. Could this be part of the problem. As far as I can tell, with my "laymans" experience, the valves are clear. Did the fact that I waited a few days to refill the washer dispenser when I noticed it empty, have any part to play in this fiasco?
Thanks again for your help!
Old May 29, 2005 | 02:46 PM
It might have sucked a peice of dirt up because it was low on fluid.
Disconnect the hose from both jets on the hood and then pull the handle and make sure fluid is coming out of both hoses.
If not then the Valve is bad.If it comes out then find a small peice of metal.Like a grabage bag tie with the paper stripped off and clean out the jet itself.
Vilenica
Jan 25, 2011 02:12 AM
Bklyn
Jan 11, 2006 12:28 AM
blahop
Dec 5, 2005 08:59 PM
colgate41
Oct 20, 2005 10:11 PM
