Seeping Headgasket
Old Jul 5, 2015 | 12:45 PM
amazon2's Avatar
Default Seeping Headgasket
What's the best stop-leak for an engine using about a quart in aprox 200 miles?
Old Jul 5, 2015 | 01:52 PM
where's this oil leaking ? burning oil is rarely a head gasket, its far more likely a blown seal (camshaft seal is #1), or badly worn rings (rare on a B230 'red block'), or valve guides (not as rare, but still not common).
does it blow blue smoke if you go down a hill at speed with engine braking ? thats valve guides.
Old Jul 5, 2015 | 01:59 PM
amazon2's Avatar
Sorry. I neglected to say "Quart of coolant". The vehicle is an 850. It's long had this issue but over a few years consumption has slowly crept up. No vapor in the exhaust so it's not time for the Blue Devil!! TD
Old Jul 5, 2015 | 02:12 PM
wait, 850? this is the 240/740/940 section, we deal with redblock not whiteblock engines.
I'll move this whole thread from the 240 section to the 850 section.
I don't like using ANY stop-leak type stuff, it all gums up the engine, unless you just want to squeeze a few 1000 more miles out of the car before scrapping it.
Old Jul 5, 2015 | 02:24 PM
amazon2's Avatar
Sorry about the wrong post location. Too many cars with too many problems. Duly noted.
Old Jul 8, 2015 | 03:31 PM
boxpin's Avatar
Are we supposed to comment on this or is it done? I think its done, you need to replace the head gasket.
Old Jul 8, 2015 | 03:36 PM
a few things to consider - you can try a coolant test kit to see if any exhaust gas is getting into the coolant, you didn't note if you have a smell in the cabin (ie slow leak in the heater core/hoses) or if you are spotting the driveway. Sad to say if nothing visible is happening (including leakage from the reservoir etc) a new head gasket may be in your future.
Old Jul 13, 2015 | 11:22 PM
Psaboic's Avatar
A new headgasket is not that hard. I did one in about 6 hours taking my time. THen again, I also did the timing belt and serpentine belt, water pump and all pulleys while I was at it. One tip if you do the headgasket, you need to replace the "one time use" stretch head bolts......
mmarreco
Nov 13, 2012 12:53 PM
volva
Apr 26, 2007 10:54 PM
brax
Sep 26, 2006 10:31 PM
www.18u
Jan 1, 2006 12:10 AM
User 6625
Jun 6, 2005 07:52 PM
