service light on
Old Mar 23, 2013 | 02:05 PM
shelby032's Avatar
Default service light on
my 96 850 the red service lght came on, car has 117,000 miles. how do you clear the light. thanks
Old Mar 23, 2013 | 04:02 PM
Take it to a Volvo dealer or a special Volvo indi shop that has the tool to reset it. It's not one that can be done easily. I have seen tools on eBay that can do it. Prices range between $75 and $125.
Most members take the bulb out. It's just a mileage oil change reminder.
Old Mar 23, 2013 | 06:42 PM
nitrosport's Avatar
I could swear that the $55 OBDII reader I had cleared the lights on my '95 850 turbo. But maybe it was just the check engine light that it cleared?
Old Mar 23, 2013 | 07:14 PM
shelby032's Avatar
ok thanks ill take it to autozone to see if they can clear it..
Old Mar 24, 2013 | 12:21 AM
They can not clear it but if you don't believe me, go right ahead. On the pre '96 models you can clear the light with the OBD-1 tool under the hood.
Old Mar 24, 2013 | 08:41 AM
slimflex2's Avatar
dude like RSPI said, autozone wont help. only volvo dealers with the VOLVO SPECIFIC scanner can clear it. dont worry about it, its just an oil change reminder.
mine is on right now and turns off after 60 seconds.
Old Mar 24, 2013 | 03:04 PM
It's not mine, it's cut and past. Since trying a local auto parts store is free I'd give it a try just in case.
850 (1996-1997) and S70 and V70 (1998)
You need an OBDII tool that resets Volvo service light codes. See this . They run about $100 to 200 -- or -- take it in to the dealer or independent Volvo mechanic and have them do it. Call to see if they charge for this first. Note: I've read reports of people having success with having the local Shucks/Pep Boys/Checker (now Oreillys) auto parts store do it.
1996 Model (Some of them)
On these models the diagnostic socket is in front of the gear stick. Switch the ignition on. As you look at the speedometer on the dash, beneath it opposite the trip reset button is a rubber plug. Remove the plug and with a thin pointer such as a ball point pen, depress the pin. This will reset the service light.
tngreg
Sep 5, 2022 07:27 PM
rred
Jun 28, 2011 08:45 AM
kijjh123
Sep 15, 2008 11:50 AM
mstrplmber
Aug 28, 2008 03:34 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
