Service light
Old Sep 25, 2006 | 02:36 PM
Dads850's Avatar
Default Service light
I know that there are many posts about this stupid light, but I can't find the answer I need. Yes, my damned service light came on yesterday and will go off after a minute or so, but I have no idea what to do about it. There are no codes or anything that I can clear. I have 226,682 miles on the car, but it is not the original engine. I don't know the exact milage of the engine, but I believe it's about 80,000. The timing belt was changed prior to the swap as per the previous owner (a Volvo mechanic). What should I do?
Old Sep 25, 2006 | 02:50 PM
robert213's Avatar
Default RE: Service light
First of all, the purpose of the "Service" light is to remind you that it is time to bring your car in for an oil change. It is nothing more than an indicator to show that 5,000 miles have elapsed since the light was reset.
Most likely your 1993 850 GLT has ODB-I. You can press a sequence of buttons in the engine compartment to reset the light. Sorry, I don't know what the sequence is. Browse thru older posts regarding service light to find out correct sequence.
Old Sep 25, 2006 | 03:22 PM
Dads850's Avatar
Not due for an oil change as it was done last month...
I know that there is a sequence to reset the lights and know how to do so, but there aren't any codes being pulled (well, other than the hvac, but that's a different issue) so I don't know what to clear.
Old Sep 25, 2006 | 03:35 PM
JimKW's Avatar
The codes turn on the CEL not the Service light. The car does not know the oil was changed. The light just comes on 5,000 miles after is was reset the last time. You're lucky you have a 93 and can reset it. I have a 97 and a 98 and mine are on every time I start the car for about a minute or two.
Old Sep 25, 2006 | 06:54 PM
MikeySq's Avatar
is a 1994 on the OBDII system as in the 97 and 98's, does reseting the service light on a 1994 have to be done at a dealer or with a OBDII scan tool or someething?
-Mike
Old Sep 25, 2006 | 09:49 PM
JimKW's Avatar
Pretty sure 94 was ODB-I and 95 was a split year where some were ODB-I and some ODB-II. I had a 94 and it was definitely not ODB-II.
Old Sep 25, 2006 | 10:03 PM
Put the wire in A-7 the sequence is 4-1-5-1 to reset the service light on a 1993/1994/1995(Early model)
Old Sep 26, 2006 | 02:01 AM
MikeySq's Avatar
ORIGINAL: tech
I was wondering if you could explain that a little further, I am not sure what/where the a-7 wire is and how to utalize the sequence
thx
-Mike
Old Sep 26, 2006 | 07:54 PM
MikeySq's Avatar
Ok figuredout the diagnostics terminal. I can put the wire in terminal 7 then what do i do, how is the sequence 4-1-5-1 utalized, what do i do with that
bare with me I'm brand new to volvo, not even a week experience yet!! haha
thx
-Mike
Old Sep 26, 2006 | 09:30 PM
Once the wire is in there make sure the key is on. Push the button 4 times and then watch for it to light up again when it does push it once. Then when it lights again push 5 times then wait for it to light then again 1 times. The the light will flash about 5 times fast to tell you it is reset.
Old Oct 24, 2006 | 09:35 AM
MikeySq's Avatar
finally had chance to try this.... just as easy as stated no probs worked like a charm!
-Mike
Old Aug 28, 2007 | 10:39 AM
phoenix_iii's Avatar
So what's the procedure for 95+
I have the simple diagnostics under the hood (push the black button, two boxes near washer resevoir cap), AND the OBD-II in the 'ash tray' area under the stereo...
I have a 95 850 Turbo (split year I guess, it seems to have both OBDI and II ??)
Old Aug 28, 2007 | 08:08 PM
RedTurbo850's Avatar
Same procedure. Look at the previous page. Socket A7 if i remember correctly.
4 shots of 1-5-1 rum is the saying.
Old Aug 29, 2007 | 08:42 PM
JPN's Avatar
JPN
The pics will be gone within the next few days and be sure to save them. Actually, if you've downloaded them from that web site, you should have the same copies in your PC in PDF format.
Cheers,
JPN
[IMG]local://upfiles/6892/10795774361D4407A18DB8F6EFDE8780.jpg[/IMG]
[IMG]local://upfiles/6892/DDCE610997D946B997453BF00D14E024.jpg[/IMG]
[IMG]local://upfiles/6892/0B2DB162EFBF485981CAB4C7E24EE14C.jpg[/IMG]
Old Aug 30, 2007 | 08:46 AM
Psaboic's Avatar
As someone said, 95 was a split year for the diagnostics. We are lucky in that our 95 does not need to have a specialtool to reset the light.For those for those of you that are bothered by the light and don't want to go to the dealer to turn it off, you can always remove the bulb from the instrument cluster. Just remember to be vigilant about service <grin>
Old Aug 30, 2007 | 04:34 PM
axelm's Avatar
The ISO tool from www.obd-2.com will reset the service light and the CEL, among other things.
tngreg
Sep 5, 2022 07:27 PM
rred
Jun 28, 2011 08:45 AM
kijjh123
Sep 15, 2008 11:50 AM
mstrplmber
Aug 28, 2008 03:34 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
