Sfifter illumination -no light?..
Old Feb 25, 2007 | 12:09 AM
m1964's Avatar
Default Sfifter illumination -no light?..
Noted today that " PRND3L " on the center console do not light up. I don't remember if they should -can someone tell me if those letters should light up or not?
Thanks.
Old Feb 25, 2007 | 12:38 AM
youngvolvoowner's Avatar
Default RE: Sfifter illumination -no light?..
You do have the lights on when you expect the center console to light up right? Becuase oddly enough just a couple hours ago I was leaving a resteraunt and it was very dark, and it didnt light up, even though the lights automatically turn on when I start the car. But, the lights were on and the PRND3L did not light up, but when I switched on the high beams I think they came on..not sure, I cant really recall becuase when I started backing out the lights werent on, but i noticed as I was going down the road a couyple minutes later, it was on..wierd..
Old Feb 25, 2007 | 12:47 AM
Light bulb is burned out.
Old Feb 25, 2007 | 01:21 AM
JPN's Avatar
JPN
Greetings from Vermont.
Yes the shifter illuminations do light, you need to take the console out and change the bulbs. Haynes' manual has a good instruction in this particular procedure, should you decide to do it yourself.
There is a thread within the first few pages on the same topic, I believe. Wait, I just found it:
https://volvoforums.com/m_50582/tm.htm
Good luck,
JPN
Old Feb 25, 2007 | 01:18 PM
Psaboic's Avatar
Yep, burned out bulb. I did this same repair on our 95 850. The dealership wanted about $20 for the bulb and holder as it was only sold as a set. I tool the console apart, accessed the bulb, went to Radio shack and found a replacement for about $3.
Good luck,
Glenn
Old Feb 25, 2007 | 01:38 PM
guptash's Avatar
As all the other members have suggested, I followed the Haynes manual and bought the bulb from RS. Job was done in about 40 - 45 minutes.
Old Feb 25, 2007 | 09:18 PM
m1964's Avatar
ORIGINAL: Psaboic
Good luck,
Glenn
Thanks -I did not think that a bulb would be around $20.00, so will go to Radioshack too. I have taken console apart before to change the window swtch.
Old Feb 25, 2007 | 10:43 PM
RedTurbo850's Avatar
Is there anywhere where I can find out which lightbulbs I need? My shifter lights are also out, plus the seat for the seatwarmers is out...
Old Feb 25, 2007 | 11:23 PM
rp850's Avatar
This is the bulb you'll need for most of the dash switches:
http://www.radioshack.com/product/in...2103780&cp
You usually don't need to buy a new holder. Just unwrap the leads from the old holder and pull the bulb out.
Old Feb 26, 2007 | 11:45 AM
Psaboic's Avatar
Yep, I clicked on the radioshack link, and that is the bulb I used.
Glenn
Old Feb 26, 2007 | 12:46 PM
JPN's Avatar
JPN
I believe I used the same bulbs as well. They were a bit brighter than the originals, but I thought the originals were a bit too dim for my taste.
I'd also like to suggest that you replace all bulbs in the center console area (except for LED's), as it'll be disappointing to see another one going out after you put everything back together.
Good luck,
JPN
Old Feb 26, 2007 | 09:33 PM
m1964's Avatar
ORIGINAL: JPN
Good luck,
JPN
How many bulb are there in the center console?
Thanks.
Old Feb 26, 2007 | 10:12 PM
JPN's Avatar
JPN
Hi m1964,
I'm not sure how many bulbs are there, but there are:
- Shifter position indicators
- Seat heater indicators
- Window indicators
- Cigar lighter indicator (I never smoke but like to have the illumination, as I'm an illumination kind of guy)
The lights on the dash switches are easy to replace, but the main cluster requires the removal of dash top cover. Should you decide to do the bulbs on the main cluster, I would replace all bulbs.
Someone please indicate exactly how many bulbs are required in the center console, as I never opened it.
Regards,
JPN
Old Feb 27, 2007 | 11:53 PM
m1964's Avatar
Thanks, I thought there were more. The sear heaters are changed from the top w/o console removal, same for the lighter. Windows indicators are part of the switch (almost new in my car), so I guess it's only one bulb for the shifter position. Anyways, will check with dealer where I am taking my DF's XC90 tomorrow - maybe the bulb is cheaper now..?
Old Feb 28, 2007 | 10:00 PM
m1964's Avatar
ORIGINAL: m1964
It is only 9.75 now.
Old Feb 28, 2007 | 11:49 PM
JPN's Avatar
JPN
JPN
Old Mar 1, 2007 | 02:45 PM
  #17
JimKW's Avatar
Pretty sure those are the same bulbs I used in my head unit also when I replaced the bulbs in it.
Vancouver850t5r
Oct 5, 2007 04:29 PM
volvojules
Aug 14, 2007 01:19 PM
thejman
Feb 14, 2007 03:11 PM
beadgc23
Jan 14, 2007 09:54 PM
euphoria
Apr 10, 2005 07:20 PM
