Sluggish wipers
Old Mar 13, 2009 | 12:48 AM
95volvo850's Avatar
Default Sluggish wipers
Anybody have the issue where their wipers behave sluggishly and even stop at times half way through the wipe motion? Is the wiper motor about to die on me?
Old Mar 13, 2009 | 08:21 AM
Psaboic's Avatar
Sounds like the motor is going, but you can check the linkage for any binding first, and also lube it up good
Old Mar 13, 2009 | 03:08 PM
Dads850's Avatar
Have the *exact* same thing happening to me... Plan to pull the transmission assembly this weekend and grease it up to see if it helps any...
Old Mar 16, 2009 | 12:15 AM
95volvo850's Avatar
So Dads850, did the grease job help? Thinking I might do the same. Just waiting for it to get a little warmer!!
Old Mar 16, 2009 | 10:06 AM
Dads850's Avatar
Well, unfortunately I never got a chance to mess with it... I'm sure that it will though. Last summer sometime (can't remember exactly when) and after 250,000 miles, the linkage worked itself lose to the point where the wipers wouldn't wipe at all so I pulled it to tighten it up. The problem that I have started about that time. So, I'm very confident that if I lube it up and adjust the torque on the linkage it will be fine
Old Mar 31, 2009 | 09:10 AM
95volvo850's Avatar
Lightbulb Follow up
As a follow up, I bought a new motor as the wipers had stopped moving entirely. Took the assembly apart, attached the new motor and still no movement! Looked at the wiper linkage a little closer and realized that the passenger side wiper pivot had seized completely. No amount of manipulation or penetrating oil would correct the issue. Strange issue as the pivot seems to be sealed but I guess these Canadian winters have taken it's toll! ;-)
So if your wipers are sluggish and stopping, check the linkage and the pivots for easy movement, as that may be the issue.
All the best,
Edward
Old Apr 1, 2009 | 07:52 AM
Dads850's Avatar
Still have yet to pull it all out to look at it. Not really a hassle right now and when it gets nice out and I'm bored I may see what's going on. However, if your pivot point is seized, can that rivet be replaced with a small bolt or something if needed? Just looking for a heads up before I pull mine...
Old Apr 1, 2009 | 10:03 AM
Ozark Lee's Avatar
You can fix them. There is a real good writeup on the subject here:
http://www.matthewsvolvosite.com/for...hp?f=1&t=18502
...Lee
dmg4
Jul 13, 2013 06:55 PM
740_in_TX
May 25, 2006 08:54 PM
Mecheng
Feb 24, 2006 12:25 AM
stever
Nov 29, 2004 10:57 PM
flyingbrick
Aug 26, 2004 05:53 PM
